5 Replies Latest reply on Feb 17, 2013 11:36 PM by starjohn2
    script not working in cs6, after working in cs5
    starjohn2 Level 1
      Hello,
      I have a script and when I try to access app.documents.length
      or app.documents[0] or app.activeDocument
      then I get the error:
      General photoshop error occurred. This functionality may not be available in this version of Photoshop
      - <no additional info is available>
      any idea ?
        • 1. Re: script not working in cs6, after working in cs5
          Paul Riggott Level 6
          As you haven't posted any code it is impossible to say what is wrong.
          app.document; or app.documents[0]; will always give you an error if there are no documents open.
          What I normally do is to check if any documents are open I.E.
          #target photoshop
          main();
          function main(){
          if(!documents.length) return;
          //do what you have to do
          • 2. Re: script not working in cs6, after working in cs5
            starjohn2 Level 1
            Thanks Paul,
            My script is like this:
            <javascriptresource>
            <name>$$$/JavaScripts/ExportGeotiff/Menu=Export Geotiff...</name>
            <about>$$$/JavaScripts/ExportGeotiff/About=Export Geotiff ^r^rCopyright 2011 Company. All rights reserved.^r^rExports document into a Geotiff image.</about>
            </javascriptresource>
            try
            alert("OK HERE");
            exportGeoTiff();
            catch(err)
            alert(err.description);
            function exportGeoTiff()
            if (app.documents.length == 0) //***** CRASHES HERE
              error("No document to export.");
            var scriptPath = getScriptPath();
            var geotifcp = getGeotifcp(scriptPath);
            var doc = app.activeDocument;
            var geo = getGeoInfo(doc);
            var inputGeoFile = saveGeoInfo(scriptPath, geo);
            var file = saveDoc(doc);
            var inputTiffFile = prepareInputTiff(scriptPath, file);
            var outputTiffFile = runGeotifcp(geotifcp, scriptPath, file);
            inputTiffFile.remove();
            inputGeoFile.remove();
            outputTiffFile.remove();
            function error(err)
            throw new Error(err);
            function getScriptPath()
            var path = "C:\\Program Files (x86)\\Company\\Common\\Maps\\";
            var folder = Folder(path);
            if (!folder.exists)
              path = "C:\\Program Files\\Company\\Common\\Maps\\";
            if (!folder.exists)
              error("Could not find map common folder.");
            return path;
            function getGeotifcp(path)
            var geotifcp = File(path + "geotifcp.cmd");
                if (!geotifcp || !geotifcp.exists)
              error("Could not find geotifcp utility.");
            return geotifcp;
            function getGeoInfo(doc)
            var raw = doc.xmpMetadata.rawData;
            var tag = "xmpMM:RenditionParams>";
            var geo = raw.substring(raw.indexOf("<" + tag) + tag.length + 1, raw.indexOf("</" + tag));
            if (!geo || (geo.length == 0))
              error("Document has no Geo-Reference information. Export cancelled.");
            //escape XML:
                geo = geo.replace(/&#xA;/g, "\r\n");
            return geo;
            function saveGeoInfo(path, geo)
            var inputGeoFile = File(path + "input.geo");
                if (!inputGeoFile)
              error("Could not create geo input file.");
            if (!inputGeoFile.open("w"))
              error("Could not open geo input file.");
            if (!inputGeoFile.write(geo))
              error("Could not write to geo input file.");
            if (!inputGeoFile.close())
              error("Could not close geo input file.");
            return inputGeoFile;
            function saveDoc(doc)
            var file = File.saveDialog("Save As", "Tiff:*.tif");
            if (!file)
              error("Save cancelled");
            doc.saveAs(file, new TiffSaveOptions(), true, Extension.LOWERCASE);
            if (file.length == 0)
              error("Saving to tiff failed. Export cancelled.");
            return file;
            function prepareInputTiff(path, file)
            var inputTiffFile = File(path + "input.tif");
                if (!inputTiffFile)
              error("Could not create input file.");
            if (inputTiffFile.exists)
              if (!inputTiffFile.remove())
               error("Could not delete input file.");
            if (!file.copy(inputTiffFile.fsName))
              error("Could not copy image to input file.");
            if (!inputTiffFile.exists)
              error("Problem copying image to input file.");
            return inputTiffFile;
            function runGeotifcp(geotifcp, path, file)
            if (!geotifcp.execute())
              error("Failed adding geo info to tiff.");
            $.sleep(1000);//let geotifcp finish
            var outputTiffFile = File(path + "output.tif");
                if (!outputTiffFile || !outputTiffFile.exists)
              error("Could not create geotiff file.");
            if (!outputTiffFile.copy(file.fsName))
              error("Failed replacing tiff image with Geotiff version.");
            return outputTiffFile;
            • 3. Re: script not working in cs6, after working in cs5
              It sounds as if your preferences are screwed, I would try resetting them and trying again.
              http://forums.adobe.com/thread/375776
              • 4. Re: script not working in cs6, after working in cs5
                shashank saxena Level 2
                Hi.
                Its easy  press n hold
                ctrl + shift + alt and launch your ps
                when prompted please
                delete your setting file.
                It will be resolved
                • 5. Re: script not working in cs6, after working in cs5
                  starjohn2 Level 1
                  Thanks Paul and Shashank! I resetted the preferences and it works now
                  Hope this will be fixed in the next release of photoshop or a better error message will show
