0 Replies Latest reply on Feb 18, 2013 6:12 AM by eduardo.linead
    Problem with as3 interface VerifyError #1053
    eduardo.linead Level 1
      Hi, im currently extending an OSMF player project, REOPS, and i am having problems with a particular class.
      The project has an interface called IControlBar which is the interface to add a Controll Bar to the player, the ControlBar class is implementing this interface, but when i add two methods to the interface i get this error:
      VerifyError: Error #1053: Illegal override of ControlBar in com.realeyes.osmfplayer.controls.ControlBar.
      without those two methos in the IControlBar interface i have no errors, but also do not have the desired functionality in the ControlBar.
      here is the IControlBar class
      IControlBar
      package com.realeyes.osmfplayer.controls
                public interface IControlBar extends ISkinElementBase
         //WITH THESE METHODS I GET THE ERROR
        function goLiveEnabled():void;
        function goLiveDisabled():void;
                           * Sets the percentage of the current progress indicator to the given
                           * percentage of the progress bar
                           * @param          p_value          (Number) percentage of the bar to set the progress indicator at
                           * @return          void
                          function setCurrentBarPercent( p_value:Number ):void;
                           * Sets the percentage of the loading indicator to the given
                           * @return          void
                          function setLoadBarPercent( p_value:Number ):void;
                           * Enables manual selection of a higher bitrate stream, if it exists
                           * @return          void
                          function bitrateUpEnabled():void;
                           * Enables manual selection of a lower bitrate stream, if it exists
                           * @return          void
                          function bitrateDownEnabled():void;
                           * Disables manual selection of a higher bitrate stream
                           * @return          void
                          function bitrateUpDisabled():void;
                           * Disables manual selection of a lower bitrate stream
                           * @return          void
                          function bitrateDownDisabled():void;
                          //  GETTER/SETTERS
                          function get autoHide():Boolean;
                          function set autoHide(value:Boolean):void;
                           * isLive
                           * Is the media playing live?
                           * @return          Boolean
                          function get isLive():Boolean;
                          function set isLive( p_value:Boolean ):void;
                           * currentTime
                           * The current time in seconds.
                           * @return          Number
                          function get currentTime():Number;
                          function set currentTime( p_value:Number ):void;
                           * duration
                           * The length of the media in seconds.
                           * @return          Number
                          function get duration():Number;
                          function set duration( p_value:Number ):void;
                           * currentState
                           * The current state. Options include: 'stopped', 'paused', and 'playing'
                           * @return          String
                          function get currentState():String;
                          function set currentState( p_value:String ):void;
                           * hasCaptions
                           * Should the control enable the closed caption controls if they exist
                           * @return          Boolean
                          function get hasCaptions():Boolean;
                          function set hasCaptions( p_value:Boolean ):void;
                          function get autoHideVolume():Boolean;
                          function set autoHideVolume( value:Boolean ):void;
      Thanks for any tip you can give me
