3 Replies Latest reply on Feb 18, 2013 9:36 AM by 99jon
    Layer to new file is green?
    philledog
      I am using elements 9.  I duplicate a photo on one layer to a new file it has a green cast over it.
      What am I doing wrong?
      Thank you,
      MEB
        • 1. Re: Layer to new file is green?
          99jon Adobe Community Professional & MVP
          How are you doing this?
          • 2. Re: Layer to new file is green?
            philledog Level 1
            I have two files.   One is a completed greeting card layout.   I have a new photo
            I scanned in as a tif file.  I want to duplicate it into th existing card file to see how it
            looks.
            When i place it or duplicate the layer of the new photo into the card file the
            new layer in the existing card file imports in as green.  The old layers stay the same
            color as before.
            • 3. Re: Layer to new file is green?
              Try opening the tiff or a saved jpeg version and then use File >> Open to open the greeting card. Drag the tiff image from the project bin directly into the main editing window and drop it on top of the greeting card.
              Use the layer stack (Window >> Layer) to drag the tiff above or below other layers to see how it looks. Also check to see if a blend mode is being used other than normal, which may have an effect on how the tiff will look.
