8 Replies Latest reply on Sep 1, 2015 8:29 PM by layj15288106
    DNG converter not functioning
    Paul Wright Photography Level 1
      I use DNG converter just about every day of my life. I'm on PC Win764. After a big archiving session where I used lossy conversion on several thousand files to crunch down the size, DNG Convereter has stopped working. Here's a screenshot:
      None of the grayed out panels work or respond. I uninstalled (V 7.2) by deleting the DNG.exe from C:\Program Files (x86)\Adobe and reinstalled  and restarted. The issue was unchanged. So I uninstalled and reverted to V7.1. Exactly the same. Next I uninstalled and ran the new V7.3. Exactly the same.
      Fortunately I can run my conversions on another identical Win7 64 PC on the network, but it's not ideal of course. Any ideas?
      Regards, Paul Wright
        • 1. Re: DNG converter not functioning
          My nearby computer expert took a look at this, and was able to solve the problem for me. He noted...
          The problem was a corrupted settings entry in the Windows registry. When the following hex value was deleted, functionality was restored:
          HKEY_CURRENT_USER\Software\Adobe\DNG Converter\7.0\Preferences
          Presumably the registry entry got corrupted somehow, but the DNG Converter software should not have been affected in this way. The software should be able to detect and repair/replace corrupted settings.
          If Adobe engineers wish to replicate the error, what follows is the corrupted registry entry:
          Windows Registry Editor Version 5.00
          [HKEY_CURRENT_USER\Software\Adobe\DNG Converter]
          [HKEY_CURRENT_USER\Software\Adobe\DNG Converter\7.0]
          "Preferences"=hex:6f,64,6e,4d,63,46,4e,44,0f,00,00,00,00,00,00,00,00,00,00,00,\
            00,00,00,00,00,00,00,00,01,00,00,00,4a,00,00,00,4a,00,00,00,43,3a,5c,55,73,\
            65,72,73,5c,50,61,75,6c,5c,50,69,63,74,75,72,65,73,5c,24,4e,65,77,50,72,6f,\
            6a,65,63,74,73,5c,41,72,72,69,75,6d,20,4f,53,43,41,53,20,32,32,2e,31,31,2e,\
            32,30,31,32,5c,44,4e,47,20,37,2e,32,20,6c,6f,73,73,79,5c,00,00,00,00,12,00,\
            00,00,00,00,00,00,12,00,00,00,00,00,00,00,12,00,00,00,00,00,00,00,01,00,00,\
            00,00,00,00,00,00,00,01,07,00,00,04,01,00,00,00,00,00,00,00,00,00,00,00,00,\
            01,00,00,00,01,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,3c,\
            00,00,00,02,00,00,00,00,00,00,00,ad,04,00,00,35,02,00,00,05,07,00,00,86,04,\
            00,00,ad,04,00,00,35,02,00,00,05,07,00,00,86,04,00,00,58,02,00,00,51,02,00,\
            00,ce,ff,ff,ff,df,ff,ff,ff,02,00,02,00,01,00,00,00,3c,00,00,00,01,00,00,00,\
            00,00,00,00,80,0a,00,00,a0,01,00,00,a6,0c,00,00,1e,03,00,00,80,0a,00,00,a0,\
            01,00,00,a6,0c,00,00,1e,03,00,00,26,02,00,00,7e,01,00,00,ce,ff,ff,ff,df,ff,\
            ff,ff,02,00,02,00,00,00,00,00,00,00,00,00,00,00,00,00
          • 2. Re: DNG converter not functioning
            EricBier Level 3
            I never would have guessed
            Thank you very much for this.  This problem has been going on since I "upgraded" to 7.0.
            • 3. Re: DNG converter not functioning
              BE-19
              I've deleted the preferences:
              And discovered that the grey blocks have disappeared... Nevertheless i can't get it to open a dialog box to select a folder :/ It just doesn't respond... Other functionalites do respond i.e. the checkboxes.
              I've treid reïnstalling diffrent versions but so far has nothing has changed ....
              Am I missing something ? any help is much appreciated this bug is driving me insane.
              thanks
              • 4. Re: DNG converter not functioning
                Mister AJB
                I have the exact same issue, it happened once on opening up with version 7.1 and decided to look for a newer version and downloaded 8.1. 8.1 has worked fine for a number of weeks but yesterday evening and today I get the exact same look as shown above and can't access the fields. This also happens after selected files have been convertered and when I want to use it again I have to 'Control' 'Alt' 'Delete' to open Windows Task Manager to close it down and when I try to close it down it pops back into life again and everything is normal.
                So I'm without a Digital Negative Converter at the moment, but I do have another computer on my Network so I'll have to try and use that as mentioned by Paul Wright.
                • 5. Re: DNG converter not functioning
                  Mister AJB Level 1
                  I've deleted the Preferences=hex: etc etc code line on RegEdit at HKEY_CURRENT_USER\Software\Adobe\DNG Converter\7.0\ and everything's fine now with 8.1 and have just converted some .NEF files successfully.
                  • 6. Re: DNG converter not functioning
                    hstanecki
                    Where do I go to enter this code to delete?
                    • 7. Re: DNG converter not functioning
                      pspamj914
                      Hello, i am researching why my DNG converter will not work.  I get this, as you said.  I am not sure where to find the solution that is listed  where is the HKEY_CURRENT_USER\Software\Adobe\DNG Converter\7.0\Preferences ??
                      I have tried loading the newest version of DNG 9.0 and that also does not work.  HELP!
                      • 8. Re: DNG converter not functioning
                        layj15288106
                        For those using version 9.0 and or above, I had found out that the easiest way to fix this is to reinstall.
                        Open your RegEdit.exe ,
                        On the side panel, access your Adobe folder>DNG Converter folder
                        Delete the DNG folder and the "Adobe DNG Converter.exe"
                        Reinstall the converter.
                        Or you can also access the reg files and use the methods as mentioned by the others.
                        Can't really find what caused this bug, but hopefully Adobe will fix this issue.
                        Keep in mind that the method that I shared is only for reinstalling (For some reason, the converter folder is no longer there even after I reinstalled the converter)
                        Such a stupid problem... URGH!!!
