7 Replies Latest reply on Feb 20, 2013 7:43 AM by try67
    Strange behavior with spell object
    jesseg7681 Level 1
      Here is a small example (pretty much the same as the example on http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/wwhelp/wwhimpl/js/html/wwhel p.htm?href=JavaScript_SectionPage.70.1.html&accessible=true for
      checkWord). The following bare minimum program adds a menu item to Acrobat under the Help menu.
      **QUESTION**
      If I comment out one line in the code (Noted as "THIS LINE" below), Acrobat *does not* create Squiggly lines under the spell misses. If I leave the line in, the script runs as expected. Is this behavior as expected? As far as I can tell it looks like a bug, but I was wondering if there is something I am missing about the spell object, is it always required to call `spell.available` before using the spell object? (I am using Acrobat Pro 9).
      app.addMenuItem( {
      cName: "CHECK",
      cUser: "CHECK",
      cParent: "Help",
      cExec: "checkfunc();",
      nPos: 0
      checkfunc = function(){
                var numWords;
                for (var i = 0; i < this.numPages; i++)
                  var ckWord = " ";
                          numWords = this.getPageNumWords(i);
                          for (var j = 0; j < numWords; j++)
                                spell.available; // <---- THIS LINE
                                    ckWord = spell.checkWord(this.getPageNthWord(i,j));
                                    if (ckWord != null)
                                              this.addAnnot
                                               page: i,
                                               type: "Squiggly",
                                               quads:  this.getPageNthWordQuads(i,j),
                                               author: "Me"
