2 Replies Latest reply on Feb 19, 2013 2:06 PM by HanielMoore
    Place item from Indesign library using applescript - how?
    HanielMoore
      I am trying to write a script that adds a slug area, then places an item from an indl file. I have had a good search and this is what I have come up with. If I remove the red then it adds a layer and slug area. I just can't manage to place the item from the library. Hopefully someone can help.
      Note: the indl file is on my desktop.
      My script:
      tell application "Adobe InDesign CS5"
                tell document preferences of active document
                          set slug right or outside offset to "100mm"
                end tell
                set myDocument to active document
                tell active document
                          set myLayer to make layer
                          set name of myLayer to "Slug"
                          set placedAsset to place asset asset "Slug" of library "Slug.indl" on myDocument
                          select placedAsset
                          move to {100, 100}
                set locked of myLayer to true
                end tell
      end tell
        • 1. Re: Place item from Indesign library using applescript - how?
          Muppet Mark Level 5
          You are asking ID to place an asset on a document of a document this is not possible… Place your asset from application level to the document… Then you can continue to work at document level later…
                    end tell
                    set placedAsset to asset "Slug" of library "Slug.indl"
            place asset placedAsset on myDocument
                    tell myDocument
                    end tell
          end tell
          • 2. Re: Place item from Indesign library using applescript - how?
            HanielMoore Level 1
            Hey, thanks for your help!
            I have now got it to open the library, place the item on a new layer, lock the layer and close the library. I can't however get it to place on all pages or align to the lower right of the page in the slug area. How would I do this?
            My script:
                      set myDocument to open "/Slug.indl"
                      end tell
                      tell myDocument
                      end tell
                      tell myDocument
                      end tell
                      set myLibrary to library "Slug.indl"
                      tell myLibrary to close
            end tell
