2 Replies Latest reply on Feb 19, 2013 8:44 AM by rokestah
    Presenter, Flash plugins and pain...
    rokestah
      I will try to make this short...
      I have the following:
      Windows 7
      Office 2010
      Presenter 8 (8.0.1 build 260)
      Acrobat Reader XI
      IE9
      I have published countless pdf's from Presenter without a hitch until recently.
      When opening the pdf I am greeted with a flash error warning, so I check my pc for flash and everything is installed and working correctly.
      What can it be I here you ask?
      I decide to re-install Flash, so I un-install the version I have and using IE9 I go to Adobe.com and install the latest version (11.6.602.168).
      This is the Active X version I here you all cry in unison!
      Yes it is!
      It is the version installed when you are using Windows 7 with IE9.
      BUT
      This version does not open my pdf's created with Presenter.
      I have to download the Flash plugin for other browsers!
      AHHHHHHHH!
      When did this happen?
      I am certain that when I last created pdf's from Presenter the standard flash plugin was able to open my files...
      I have hundreds of students who may all have to download an alternative plugin because the IE9 active x plugin does not open the pdf.
      This means downloading an alternative browser and installing flash from within or me sending a link out with the pdf's.
      This cannot be right... surely.
      please tell me I am doing something wrong and there is a simple solution or point me in the right direction...
      thx
