2 Replies Latest reply on Nov 14, 2007 2:25 AM by KlausBusse
    Tree with custom labels crashes during scrolling
    KlausBusse Level 1
      We have a tree that uses custom icons for different folder/data types. The tree contains about 150 items of around 15 types. The icons are assigned correctly and the tree works just fine.
      However: If we scroll the tree up and down, it eats up some resource, and after a couple of seconds of constant back and forth scrolling the app hangs up completely.
      The icons are embedded btw. If we don's use custom icons, then we don't get a crash here.
      Any idea what's going wrong here? What can be done to fix it?
      Klaus
      P.S. To create the we use a label function like this:
      public static function treeLabel(item:Object):String
      var node:XML = XML(item);
      var cType:String = node.@contentType.toString();
      if(Assets.getInstance().hasOwnProperty("icon"+cType))
      var icon:Class = Assets.getInstance()["icon"+cType];
      _application.portalTree.setItemIcon(node, icon, icon);
      return node.@headline.toString();
