3 Replies Latest reply on Feb 19, 2013 7:07 PM by Chris Cox
    PS OpenCL Support for GeForce GTX 460 on Windows
    alanherron
      I am trying to enable OpenCL support in photoshop.  Below you will find detailed specs
      OS Information: Microsoft Windows 7 Professional  64bit  6.1.7601 Service Pack 1 Build 7601
      Processor: Intel Core i7 950 (4x 3.06GHz/8MB L3 Cache) clocked to 3.2Ghz 159.99x20.0
      Motherboard: Sabertooth X58
      Memory: 12 GB [4 GB X3] DDR3-1600
      HDD: 2x 60 GB Corsair Force Series F60 MLC SSD Run in RAID 0
      System Drive:  1TB HDD
      GPU Information :
      2x - NVIDIA GeForce GTX 460 - 1GB - PALIT Sonic Platinum - Core: 800MHz - SLI Mode (Dual Cards)
      For quick reference on the cards check here:
      http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-460
      I have done a clean install of the GeForce 314.07 Drivers  (releaesd 2/18/2013).   In addition i have done clean installs of 3 Prior GeForce releases.
      In case this cant be seen well this can also be found at http://www.alanherron.com/system_info.png
      For detailed specs check  http://www.alanherron.com/gpu_caps_viewer_report.txt
      I can run OpenCL benchmarking tests and they work great, but I still cannot active it in photoshop.
      Ive tried using sniffer_gpu.exe in the photoshop folder at numerous different times and intervals, (while photoshop is open, after i close it, after a fresh reboot), yet i still cannot get it enabled in photoshop.
      I am exhaused from searching the web for answers and I still cant figure this out.
        • 1. Re: PS OpenCL Support for GeForce GTX 460 on Windows
          Level 7
          Look at Help -> System Info for clues about your GPU and why it's driver isn't working for OpenCL.
          • 2. Re: PS OpenCL Support for GeForce GTX 460 on Windows
            alanherron Level 1
            Thanks for the reply Chris.  I realize it says unavailable, but the cards do support OpenCL.
            Here is the info below:
            Adobe Photoshop Version: 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00) x32
            Operating System: Windows 7 64-bit
            Version: 6.1 Service Pack 1
            System architecture: Intel CPU Family:6, Model:10, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 3708 MHz
            Built-in memory: 12279 MB
            Free memory: 7325 MB
            Memory available to Photoshop: 3255 MB
            Memory used by Photoshop: 59 %
            Image tile size: 128K
            Image cache levels: 4
            OpenGL Drawing: Enabled.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            OpenGL Allow Old GPUs: Not Detected.
            OpenCL Unavailable
            OpenGL Version: 3.0
            Video Rect Texture Size: 16384
            OpenGL Memory: 1023 MB
            Video Card Vendor: NVIDIA Corporation
            Video Card Renderer: GeForce GTX 460/PCIe/SSE2
            Display: 2
            Display Bounds: top=0, left=0, bottom=1080, right=1920
            Display: 1
            Display Bounds: top=0, left=1920, bottom=1080, right=3840
            Video Card Number: 2
            Video Card: NVIDIA GeForce GTX 460
            Driver Version: 9.18.13.1407
            Driver Date: 20130209000000.000000-000
            Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
            Video Mode: 1920 x 1080 x 4294967296 colors
            Video Card Caption: NVIDIA GeForce GTX 460
            Video Card Memory: 1024 MB
            Video Card Number: 1
            Serial number: 90970573932821993216
            Application folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\
            Temporary file path: C:\Users\ALANHE~1\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              G:\, 1.36T, 804.3G free
              C:\, 111.7G, 25.1G free
            • 3. Re: PS OpenCL Support for GeForce GTX 460 on Windows
              Level 7
              Either the drivers don't support OpenCL, or something is wrong with the driver installation.
              You'll have to talk to NVidia about why their recent driver is not correctly supporting OpenCL on your system.
