5 Replies Latest reply on Nov 14, 2007 7:27 PM by Blindgator
    list shuffle
    Blindgator
      I have a list with names of cards that I am using in a game that I was making and was wondering if there was any way to randomly shuffle the list so that each time it would be in a differant order?
      Thanks for the help
      Brian
        • 1. Re: list shuffle
          McFazstp Level 1
          on ShuffleList var_list
          repeat with n = 1 to var_list.count
          n_random = random( var_list.count )
          if ( n = n_random ) then
          next repeat
          end if
          item1 = var_list[n]
          var_list[n] = var_list[n_random]
          var_list[n_random] = item1
          end repeat
          end
          • 2. Re: list shuffle
            Blindgator Level 1
            Thanks for the quick response but could someone please explain to me everything that the script he posted is doing. Being new to director I dont quite understand all of it and would appreciate the help.
            • 3. Re: list shuffle
              the real POTMO Level 1
              it loops thru the whole list.
              With every item in the list it takes a random other index and switches tose values
              1. A
              2. B
              3. C
              4. D
              5. E
              You start with 1 (A)
              take a random other position in list, say index 4 (D). Swap them so now the list looks like this
              1.D
              2.B
              3.C
              4.A
              5.E
              Now take index 2 (B) and swap it with a random other position say 3 (C)
              1.D
              2.C
              3.B
              4.A
              5.E
              keep on looping this way until you have swapped all items.
              you can also do it like this
              make two lists
              orgList = [A,B,C,D,E]
              resultList = []
              --repeat while there are items left in the original list
              repeat while orgList.count > 0
              fromPos = random(orgList.count)
              toPos = random(resultList.count)
              resultList.addAt(toPos, orgList[fromPos])
              orgList.deleteAt(fromPos)
              end repeat
              now resultList is a shuffeled version of orgList
              • 4. Re: list shuffle
                McFazstp Level 1
                -- process with n = 1 to end of list
                -- get random list position
                -- check if same as current index n
                -- skip if same
                next repeat
                end if
                -- store current value
                item1 = var_list[n]
                -- set to value from random position
                -- set random position to stored value
                end repeat
                -- no need to return value because original list is already changed
                end
                • 5. Re: list shuffle
                  Blindgator Level 1
                  Got it working. Really appreciated the help
                  Muchas Gracias
