1 Reply Latest reply on Sep 28, 2016 10:10 AM by Angelworks
    ExceptionDeployer
    garycoyle
      Hi
      I used the ExceptionDeployer.exe with the --workflow=install --mode=post command and all works fine to install the products in the eceptions folder for InDesign using SCCM 2012. How about the UNINSTALL...? i understand that the only argument that currently applies to --workflow is "install".....if the uninstall is to be done manually then it stands to reason that to uninstall "PDF Settings CS6" is to use msiexec /x....what is the command to uninstall "AdobeHelp"
      Gary
