1. Re: Inbox Notification from Workflow
Sham HCFeb 28, 2013 8:33 PM (in response to mizakr)
Hi Michal,
You can't call implementation class. Get the reference of inboxmanager and then create message. Ex:-
/** @scr.reference */
private InboxManager inboxManager;
final Message msg = this.inboxManager.createMessage(....);
Sham
2. Re: Inbox Notification from Workflow
mizakr Feb 28, 2013 11:40 PM (in response to Sham HC)Hi Sham,
it's not working: in Web Console I still get a message that
com.day.cq.wcm.notification.inbox -- Cannot be resolved
my code:
import java.io.IOException;
import com.day.cq.security.Authorizable;
import com.day.cq.wcm.notification.inbox.InboxManager;
import com.day.cq.wcm.notification.inbox.Message;
public class MessageCreator {
public void sendMessage(Authorizable user, String reason) throws IOException {
final Message msg = this.inboxManager.createMessage(user);
msg.setReason(reason);
msg.save();
any others idea?
3. Re: Inbox Notification from Workflow
Jörg HohMar 1, 2013 11:16 AM (in response to mizakr)
Obviously your bundle does not provide the necessary import statements. Pleas check your maven setup (if you have one), that you have the proper dependencies declared.
Jörg
4. Re: Inbox Notification from Workflow
Sham HCMar 2, 2013 1:32 PM (in response to Jörg Hoh)
Hi Michal,
Along with fixing Jörg update, in your code use reference for inboxManager.
Sham
5. Re: Inbox Notification from Workflow
mizakr Mar 3, 2013 9:26 AM (in response to Sham HC)hey guys,
maven dependency for notification:
<dependency>
<groupId>com.day.cq.wcm</groupId>
<artifactId>cq-wcm-notification</artifactId>
</dependency>
I checked dependency in CQ5:
when I'm looking for "com.day.cq.wcm.notification.inbox.InboxManager" I get:
com.day.cq.wcm.notification.inbox NOT EXPORTED what does it mean? :/
Sham:
what you mean when you say "in your code use reference for inboxManager"?
6. Re: Inbox Notification from Workflow
Jörg HohMar 3, 2013 11:47 AM (in response to mizakr)
That's because the bundle cq-wcm-notifications has this export list:
Exported Packages
com.day.cq.wcm.notification,version=0.0.0
com.day.cq.wcm.notification.email,version=0.0.0
It does not export the package com.day.cq.wcm.notification.inbox.InboxManager.
(In CQ 5.5 this package is documented in the API docs, but that's probably an error, in 5.6 it is not contained in the official API docs anymore. On the other hand there is a service "InboxManager" available on CQ 5.5 ...)
I recommend you to file a Daycare ticket to report this mismatch and to ask if that's a bundle problem (missing export statement) or if this service is not considered as public API.
kind regards,
Jörg
ps: Sham recommended you to write
@Reference
InboxManager inboxMgr;
7. Re: Inbox Notification from Workflow
maruthid Jul 1, 2013 12:38 AM (in response to Jörg Hoh)Hi Jorg,
I am also having same issue in CQ5.5.2. Since OOTB bundle is not exporting can we export from our pom.xml?
If we export it is resolving but illegal argument error is coming.
Below is the error stack.
01.07.2013 12:49:59.328 *ERROR* [OsgiInstallerImpl] com.aaa.dam.abc.core.OURCustomDamCore [com.aaa.dam.abc.services.workflow.impl.CustomWorkFlowStep] The unbindInboxManager method has thrown an exception (java.lang.IllegalArgumentException: argument type mismatch) java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:227)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:38)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:591)
at org.apache.felix.scr.impl.helper.BaseMethod$NotResolved.invoke(BaseMethod.java:548)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:472)
at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager. java:1129)
at org.apache.felix.scr.impl.manager.DependencyManager.unbind(DependencyManager.java:993)
at org.apache.felix.scr.impl.manager.DependencyManager.close(DependencyManager.java:880)
at org.apache.felix.scr.impl.manager.ImmediateComponentManager.disposeImplementationObject(I mmediateComponentManager.java:268)
at org.apache.felix.scr.impl.manager.ImmediateComponentManager.deleteComponent(ImmediateComp onentManager.java:135)
at org.apache.felix.scr.impl.manager.DelayedComponentManager.deleteComponent(DelayedComponen tManager.java:67)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$Satisfied.deactivate(AbstractC omponentManager.java:1223)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractCom ponentManager.java:339)
at org.apache.felix.scr.impl.manager.DependencyManager.serviceRemoved(DependencyManager.java :346)
at org.apache.felix.scr.impl.manager.DependencyManager.serviceChanged(DependencyManager.java :253)
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispat cher.java:871)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java :733)
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:662 )
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:3765)
at org.apache.felix.framework.Felix.access$000(Felix.java:80)
at org.apache.felix.framework.Felix$2.serviceChanged(Felix.java:722)
at org.apache.felix.framework.ServiceRegistry.unregisterService(ServiceRegistry.java:130)
at org.apache.felix.framework.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.jav a:129)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterComponentService(Abs tractComponentManager.java:565)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$Satisfied.deactivate(AbstractC omponentManager.java:1222)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.disposeInternal(AbstractCompon entManager.java:358)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManag er.java:197)
at org.apache.felix.scr.impl.config.ImmediateComponentHolder.disposeComponents(ImmediateComp onentHolder.java:356)
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java: 307)
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:329)
at org.apache.felix.scr.impl.Activator.bundleChanged(Activator.java:196)
at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatc her.java:807)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java :729)
at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:610)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:3754)
at org.apache.felix.framework.Felix.stopBundle(Felix.java:2199)
at org.apache.felix.framework.BundleImpl.stop(BundleImpl.java:958)
at org.apache.felix.framework.BundleImpl.stop(BundleImpl.java:945)
at org.apache.sling.installer.core.impl.tasks.BundleUpdateTask.execute(BundleUpdateTask.java :88)
at org.apache.sling.installer.core.impl.OsgiInstallerImpl.executeTasks(OsgiInstallerImpl.jav a:733)
at org.apache.sling.installer.core.impl.OsgiInstallerImpl.run(OsgiInstallerImpl.java:247)
at java.lang.Thread.run(Thread.java:680)
8. Re: Inbox Notification from Workflow
Jörg HohJul 1, 2013 8:10 AM (in response to maruthid)
You cannot export private packages of another bundle. And as stated above: please contact Daycare support if the documentation of the InboxManager as public API is an error, or if the missing export statement in the OSGI bundle is the problem.
kind regards,
Jörg
