5 Replies Latest reply on Feb 20, 2013 2:13 PM by Nivis Tigridis
    What to put on what HDD for best performances
    Nivis Tigridis Level 1
      A New HDD just fallen on my lap recently, I'm new into Premiere and I wished to use it for my video edition.
      Here my current Spec:
      CPU  I7-2600K @ 4.6Ghz
      RAM: 2 * [ RipjawsX ] F3-17600CL7D-4GBXHD (8 Gig total)
      Motherboard: GA-P67A-UD5-B3
      Hard Drive: 2 * Seagate Barracuda 7200.12 500GB in Raid 0
      Graphics Gigabyte GeForce GTX 570 Fermi Windforce
      The new HDD: is a ST 7200.14 500 gig.
      Right now, because I have no choice, all is on the RAID 0 array.
      I want to know for what / what to put on the new 500 gig HDD I've got.
      Best regards,
        • 1. Re: What to put on what HDD for best performances
          I don't do raid, but this is how I use 3 drives
          1 - 320Gig Boot for Win7 64bit Pro and ALL program installs
          2 - 320Gig data for video project files... When I create a project on #2 drive, the various work files follow, so my boot drive is not used for the media cache folders and files
          3 - 1Terabyte data for all video files... input source & output export files... this would be your raid
          • 2. Re: What to put on what HDD for best performances
            Ok I juste have 2 disk, Windows is on the RAID as well as Premiere.
            I COULD move Premiere out of the RAID but Windows stay where it is (for now).
            Therefore in my situation / configuration I would use the extra HDD for Project files.
            I was thinking to put the "source" materials there too and use the RAID for the final output / Temp processing items.
            Is that correct or I didn't understood correctly?
            Thank you,
            • 3. Re: What to put on what HDD for best performances
              Jim_Simon Level 9
              Here's what I'd do.
              500GB - Windows and Programs
              1TB - Projects/Scratch/Exports
              1TB - Media
              • 4. Re: What to put on what HDD for best performances
                SAFEHARBOR11 Most Valuable Participant
                Your media (video clips) should never be on the same hard drive as Windows. A dedicated drive is always recommended for NLE editing.
                I would make the new 500GB the C: drive, and then use the RAID for video/projects files.
                You would need to reinstall Windows, OR - I think you could use the Image Backup feature in Windows 7 and be able to duplicated the OS onto the new drive.
                As a side note, if you can boost your RAM to 16GB, you will see some performance increase, helped with my Core i7 - 2600 system. Memory is very inexpensive at this time.
                Jeff Pulera
                Safe Harbor
                • 5. Re: What to put on what HDD for best performances
                  TY Safeharbo11, you've answered my question correctly.
                  For now I don't plan to mess around Windows and RAID configuration, I don't need a huge performance boost.  When I'll do I'll probably go the SSD Route for Windows.
                  For the RAM, I have the cream of the crop as RAM speed / latency goes, and I don't use more then 50-55% of it in my projects.  So I won't touch it for now (they cost me 125-130$ / 4 gig kit; I have 2 of thooses).
                  I doubt the Image would do since I'm Running a On Board RAID Array (not a dedicated card for it).  I will still look into it.
                  Bottom line I'll move the Video source files on the new hdd for now (to have at least Windows & Premiere on a different drive then the Video files).
                  I'll keep looking for a other 500 Gig that I could use to create a other Raid 0 array.
                  Thanks you all.
