15 Replies Latest reply on Jun 2, 2013 12:15 PM by Jörg Hoh
    some libs can not found
    Mathis.Wan
      Hello, I'm new  to CQ5 and I'm following the "cq5_guide_developer" to practice my first project. It's very smooth until I want to download "cq5libs" from my local CQ5.5 server.
      Here are the content of the guide I'm following:
      Proceed as follows:
      1. In your file system, create a CQ5 libraries folder called cq5libs. This folder can be created anywhere.
      2. Under cq5libs, create the folders: cq, sling and wcm.
      3. From the system command line go to .../cq5libs/cq and execute vlt co http://localhost:4502/crx /libs/cq/install . to export the libraries stored under /libs/cq/install from the CQ5 server.
      4. From the system command line go to .../cq5libs/sling and execute vlt co http://localhost:4502/crx /libs/sling/install . to export the libraries stored under /libs/sling/install from the CQ5 server.
      5. From the system command line go to .../cq5libs/wcm and execute vlt co http://localhost:4502/crx /libs/wcm/install . to export the libraries stored under /libs/wcm/install from the CQ5 server.
      6. In Eclipse, right-click the ui project, select Build Path, then Configure Build Path. In the dialog select the Libraries tab.
      7. Click Add External JARS..., navigate to .../cq5libs/cq/jcr_root, select all the jar files and click Open.
      8. Click Add External JARS..., navigate to .../cq5libs/sling/jcr_root, select all the jar files and click Open.
      9. Click Add External JARS..., navigate to .../cq5libs/wcm/jcr_root, select all the jar files and click Open.
      10. Click Add External JARS..., navigate to <cq-installation-dir>/crx-quickstart/server/lib/container, select all the jar files and click Open.
      11. Click OK.
      I got a error message when I tried to execute "vlt co http://localhost:4502/crx /libs/cq/install " with username and password, but server reponsed like this:
      Connecting via JCR remoting to http://localhost:4502/crx/libs/cq
      [WARN ] Authentication required to access repository descriptors
      [ERROR] checkout: com.day.jcr.vault.vlt.VltException: Unable to mount filesystem
      caused by: javax.jcr.ItemNotFoundException: Not Found
        caused by: org.apache.jackrabbit.webdav.DavException: Not Found
      Dose anybody have any idea about it?
