3 Replies Latest reply on Feb 23, 2013 4:24 AM by designmon79
    Anchored object in XML
    designmon79
      Hi All,
      I am trying to select a xml TAG  <ital></ital> if it has anchored object. So that I can remove XML TAG from anchored object.
      The below code is working if there is no text between <ital> xml tag.
      Can anyone please help me to change this code to select the tag if it has anchored object.
      Want to untag if selected is not a string.
      if(ital[j].contents == "")
                  ital[j].select()
                  alert("Selected");
                  exit();
                   return;
      Mon
        • 1. Re: Anchored object in XML
          designmon79 Level 1
          Need to untag below condition.
          please help.
          Mon
          • 2. Re: Anchored object in XML
            R-Bala-Krishnan Level 2
            Try:
            var myDoc = app.documents.item(0);
            getAllXMLElements(myDoc);
            function getAllXMLElements(elm){
                      for(var i1=0; i1<elm.xmlElements.length; i1++){
                    if((elm.xmlElements[i1].markupTag.name == "ital") && (elm.xmlElements[i1].contents.match (RegExp('^\uFFFC$')) != null)){
                            var goBack = elm.xmlElements[i1].parent;
                            elm.xmlElements[i1].untag();
                            getAllXMLElements(goBack);
                        else{
                            getAllXMLElements(elm.xmlElements[i1]);
            Thanks & regards,
            Balakrishnan R
            • 3. Re: Anchored object in XML
              designmon79 Level 1
              Thank you so much, Balakrishnan.
