2 Replies Latest reply on Feb 28, 2013 8:24 PM by Sham HC
    Issue while starting a workflow using a form submission cq5
    chamila.fernando Level 1
      I have followed the below mentioned tutorial and completed it.
      http://dev.day.com/docs/en/cq/current/workflows/create-models.html#par_reference
      Once done, I did try to start the workflow using a normal form submission, by giving workflow name in the "Start Workflow" box.
      Once clicked it will send the notification to my inbox, and when I double click, the form 1 will be displayed. Once submitted form two will be displayed.
      But when I submit the form 2, it thorws the below exception.
      But when I start the same workflow using the sidekick, It works perfectly fine. I am guessing that the {payload}.html is not getting set when the WF is initaited by a form submission.
      Could you please help with this. Thank you !
      Exception
      Not Found
      Cannot serve request to /content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/1361448480595_ 27.html in org.apache.sling.servlets.get.DefaultGetServlet
      Request Progress:
            0 (2013-02-21 17:38:19) TIMER_START{Request Processing}
            0 (2013-02-21 17:38:19) COMMENT timer_end format is {<elapsed msec>,<timer name>} <optional message>
            0 (2013-02-21 17:38:19) LOG Method=GET, PathInfo=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/13614 48480595_27.html
            0 (2013-02-21 17:38:19) TIMER_START{ResourceResolution}
            1 (2013-02-21 17:38:19) TIMER_END{1,ResourceResolution} URI=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/1361448480 595_27.html resolves to Resource=JcrNodeResource, type=sling:Folder, superType=null, path=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/136144848 0595_27
            1 (2013-02-21 17:38:19) LOG Resource Path Info: SlingRequestPathInfo: path='/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/13614484 80595_27', selectorString='null', extension='html', suffix='null'
            1 (2013-02-21 17:38:19) TIMER_START{ServletResolution}
            1 (2013-02-21 17:38:19) TIMER_START{resolveServlet(JcrNodeResource, type=sling:Folder, superType=null, path=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/136144848 0595_27)}
            1 (2013-02-21 17:38:19) TIMER_END{0,resolveServlet(JcrNodeResource, type=sling:Folder, superType=null, path=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/136144848 0595_27)} Using servlet org.apache.sling.servlets.get.DefaultGetServlet
            1 (2013-02-21 17:38:19) TIMER_END{0,ServletResolution} URI=/content/usergenerated/mywebsite/en/products/product12/cq-gen1361441037192/1361448480 595_27.html handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet
            1 (2013-02-21 17:38:19) LOG Applying Requestfilters
            1 (2013-02-21 17:38:19) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet
            1 (2013-02-21 17:38:19) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter
            1 (2013-02-21 17:38:19) LOG RedirectFilter did not redirect (MobileUtil.isMobileResource() returns false)
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.core.impl.warp.TimeWarpFilter
            1 (2013-02-21 17:38:19) LOG Applying Componentfilters
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
            1 (2013-02-21 17:38:19) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
            1 (2013-02-21 17:38:19) TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0}
            1 (2013-02-21 17:38:19) LOG No renderer for extension html
            1 (2013-02-21 17:38:19) LOG Applying Error filters
            1 (2013-02-21 17:38:19) TIMER_START{handleError:status=404}
            1 (2013-02-21 17:38:19) TIMER_END{0,handleError:status=404} Using handler /libs/sling/servlet/errorhandler/404.jsp
            2 (2013-02-21 17:38:19) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config={}), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@88fc5d1), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@170420bb), Config(type=contentsync, config=org.apache.sling.jcr.resource.JcrPropertyMap@1000e0cb), serializer=Config(type=htmlwriter, config={}))}
            2 (2013-02-21 17:38:19) TIMER_END{2,Request Processing} Dumping SlingRequestProgressTracker Entries
      ApacheSling/2.2 (Day-Servlet-Engine/4.1.24, Java HotSpot(TM) 64-Bit Server VM 1.7.0_07, Windows 7 6.1 amd64)
