1 Reply Latest reply on Nov 14, 2007 4:35 AM by RoboColum(n)
    Opening Video Files in Different Languages
    Brook21679
      How can I dynamically (at run time) change the behavior of Help.chm? My goal is to be able to open a video file of the appropriate language (French, German, etc). For example, the German and French video file for a given topic will have the same name but will be located in different folders. How can we tell Help.chm to open one or the other?
        • 1. Re: Opening Video Files in Different Languages
          RoboColum(n) Level 5
          You can't. Could you handle it by producing different version of your help file (using build tags to limit the output to French, German, etc.). Then with your developers you can code a solution that installs only the required version. Other than that, on your default topic, have some flags. When a user clicks a flag, the correct video is opened.
