8 Replies Latest reply on Dec 8, 2015 2:10 AM by Joonastahtinen
    lighting in CS6 3D mode
    candlecatrat Level 1
      Hi, I'm working on a mac and I'm a newcomer to the 3D features in CS6,
      I have taken a flat pattern design and created a cylinder from the mesh preset dropdown. Screenshot attached of the rasterized 3d layer.
      I have the angle and scale I want, but I'd like to remove all shadowing. Is there a way of turning lighting off completely and retaining the colours of the original flat pattern design?
      Thanks in advance,
      Ben
        • 1. Re: lighting in CS6 3D mode
          conroy Level 5
          You have a couple of options.
          An OpenGL render is easy: just set Surface to "Unlit Texture" in the properties for Scene.
          A high quality render is a little trickier. I'll tell you how to do that if the OpenGL isn't good enough.
          • 2. Re: lighting in CS6 3D mode
            Perfect, thanks very much Conroy.
            • 3. Re: lighting in CS6 3D mode
              Joonastahtinen
              Hi Conroy,
              I would like to know how to get a high quality render with the unlit texture option. I would like to render quicker, but as well The textures seem to exposure wrong when I use GI.
              So any tips? @conroy
              • 4. Re: lighting in CS6 3D mode
                SG... Adobe Employee
                Before going the Ray Trace route, check your Performance> Advanced GPU settings. If it is currently set to Advanced try selecting Basic first, and then opening the 3D file. The color shift you're seeing might be due to the color management being handled on the GPU, and setting to Basic forces CPU color management for 3D layers @ GL rendering.
                If that doesn't work, or you were already on Basic, then you'll need to go the RayTrace route which involves changing a few scene options.
                [Change your workspace to '3D' if your not already there]
                1) In the 3D panel go to the material that has the diffuse map you want to render w/o shadows and select it. Then find the Ambient color value selector in the Properties panel. Click the swatch and then choose White.
                2) Back in the 3D panel, turn off any lights in your scene.
                3) Also in the 3D panel, select Environment, and then in the Properties panel make sure the IBL box is checked on. Go to the icon on the right, click and then select 'Remove Texture'. If the color is not white, click on the color selector swatch and change it to white too. Also uncheck the 'Shadow' box to remove ambient occlusion effects.
                4) 3D> Render 3D layer and let it run until the quality if acceptable. You can exit progress at any time with ESC key.
                If you need screen shots to follow steps a bit better let me know. I just realized I was walking thru with Ps CC 2015.1, and the panel layouts may have changed since Ps CS6. If something looks way off it is likely due to a UI change. I'll go back to CS6 and take a look if there's a major disconnect; let me know.
                regards,
                steve
                • 5. Re: lighting in CS6 3D mode
                  Joonastahtinen Level 1
                  Thanks Steve,
                  The fist tip of changing the performance from advance to basics did speed up things a lot. But it didn't solve the issue.
                  to clarify my issue bit more:
                  1. Using unlit textures rendered low quality version of the image, still even with the steps you provided.
                  2. Using Solid texture option the render time was realy slow and the image was really dark, but after the steps the render time was quicker, but the image was still slow.
                  The performance>advance did speed things up a lot, but the image is still very dark.
                  I think it's because it renders the image to linear gamma (even when render to linear color check box is off in the 3d panel) or something near it, because the image gets very similar to the low resolution preview when I apply a Exposure adjustement layer with 2,2 gamma correction. All most the same but not the same.
                  It will do for now, but It would be nice to understand how the gamma of photoshop 3D works so that I could use it to it's full potential.
                  • 6. Re: lighting in CS6 3D mode
                    If I check the linearize color checkpoint, it renders non linear exposure. I need to look into the linear workflow to understand things bit better.
                    • 7. Re: lighting in CS6 3D mode
                      Hi Joonas,
                      Do you have current GPU drivers for your card? And which version of Ps CS6 do you have? Can you go to Help> System Info... and paste the text in a reply?
                      I'm not fully versed in the Linearize Colors option, and there may be bugs in the certain CS6 versions.
                      regards,
                      steve
                      • 8. Re: lighting in CS6 3D mode
                        I'm running on CC
                        Here you go:
                        Adobe Photoshop Version: 2015.0.1 20150722.r.168 2015/07/22:23:59:59 CL 1032103  x64
                        Operating System: Mac OS 10.10.5
                        System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                        Physical processor count: 4
                        Logical processor count: 8
                        Processor speed: 2000 MHz
                        Built-in memory: 16384 MB
                        Free memory: 9378 MB
                        Memory available to Photoshop: 13940 MB
                        Memory used by Photoshop: 70 %
                        Design Space: Disabled.
                        Artboards: Enabled.
                        3D Multitone Printing: Disabled.
                        Highbeam: Enabled.
                        Image tile size: 1024K
                        Image cache levels: 4
                        Font Preview: Medium
                        TextComposer: Latin
                        Display: 1
                        Main Display
                        High DPI Monitor
                        Display Bounds: top=0, left=0, bottom=1200, right=1920
                        OpenGL Drawing: Enabled.
                        OpenGL Allow Old GPUs: Not Detected.
                        OpenGL Drawing Mode: Advanced
                        OpenGL Allow Normal Mode: True.
                        OpenGL Allow Advanced Mode: True.
                        AIFCoreInitialized=1
                        AIFOGLInitialized=1
                        OGLContextCreated=1
                        NumGLGPUs=1
                        NumCLGPUs=1
                        glgpu[0].GLVersion="2.1"
                        glgpu[0].GLMemoryMB=1536
                        glgpu[0].GLName="Intel Iris Pro OpenGL Engine"
                        glgpu[0].GLVendor="Intel Inc."
                        glgpu[0].GLVendorID=32902
                        glgpu[0].GLRectTextureSize=16384
                        glgpu[0].GLRenderer="Intel Iris Pro OpenGL Engine"
                        glgpu[0].GLRendererID=16925954
                        glgpu[0].HasGLNPOTSupport=1
                        glgpu[0].CanCompileProgramGLSL=1
                        glgpu[0].GLFrameBufferOK=1
                        glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                        glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                        glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                        glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                        glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                        glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                        clgpu[0].CLPlatformVersion="1.2 (May 10 2015 19:38:45)"
                        clgpu[0].CLDeviceVersion="1.2 "
                        clgpu[0].CLMemoryMB=1536
                        clgpu[0].CLName="Iris Pro"
                        clgpu[0].CLVendor="Intel"
                        clgpu[0].CLVendorID=16925952
                        clgpu[0].CLDriverVersion="1.2(Jul 29 2015 02:40:39)"
                        clgpu[0].CUDASupported=0
                        clgpu[0].CLBandwidth=4.4799e+10
                        clgpu[0].CLCompute=170.813
                        License Type: Subscription
                        Serial number: 90970762849610807187
                        Application folder: /Applications/Adobe Photoshop CC 2015/
                        Photoshop scratch has async I/O enabled
                        Scratch volume(s):
                          Startup, 233,0G, 57,3G free
                        Required Plug-ins folder: /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/Plug-Ins/
                        Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2015/Plug-ins/
                        Installed components:
                           AdbePM.framework   AdbePM   2.3.00.32699   1.563170
                           adobe_caps.framework   adobe_caps   9.0.0.5   1.584361
                           AdobeACE.framework   AdobeACE   2.20.02.34307   79.562242
                           AdobeAGM.framework   AdobeAGM   4.30.48.34307   79.562242
                           AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                           AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                           AdobeBIB.framework   AdobeBIB   1.2.03.34307   79.562242
                           AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.562242
                           AdobeCoolType.framework   AdobeCoolType   5.15.00.34307   79.562242
                           AdobeCrashReporter.framework   AdobeCrashReporter   7.1.4
                           AdobeExtendScript.framework   AdobeExtendScript   4.5.6.2   80.1017022
                           AdobeJP2K.framework   AdobeJP2K   1.2.2.34862   79.258447
                           AdobeLinguistic.framework      20256
                           AdobeMPS.framework   AdobeMPS   5.8.1.34307   79.562263
                           AdobeOwl.framework   AdobeOwl   5.2.7
                           AdobePDFL.framework   AdobePDFL   15.0.0.34348   79.133307
                           AdobePDFSettings.framework   AdobePDFSettings   1.4
                           AdobePIP.framework   AdobePIP   7.2.1.3600
                           AdobeScCore.framework   AdobeScCore   4.5.6.2   80.1017022
                           AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                           AdobeXMP.framework   AdobeXMPCore   79.157747   79.157747
                           AdobeXMPFiles.framework   AdobeXMPFiles   79.157747   79.157747
                           AdobeXMPScript.framework   AdobeXMPScript   79.157747   79.157747
                           ahclient.framework   ahclient   2.0.0.1
                           AIDE.framework   AIDE   1.5.0.34359   79.562488
                           aif.framework   aif   6.0.00.1   1.
                           amtlib.framework   amtlib   9.0.0.21
                           boost_date_time.framework   boost_date_time   8.0.0.0
                           boost_signals.framework   boost_signals   8.0.0.0
                           boost_system.framework   boost_system   8.0.0.0
                           boost_threads.framework   boost_threads   8.0.0.0
                           Cg.framework   NVIDIA Cg
                           CIT.framework   CIT   2.3.7.33275   156750
                           CITThreading.framework   CITThreading_boost   2.3.7.33275   156750
                           dvaaudiodevice.framework   dvaaudiodevice   8.0.0.0
                           dvacore.framework   dvacore   8.0.0.0
                           dvamarshal.framework   dvamarshal   8.0.0.0
                           dvamediatypes.framework   dvamediatypes   8.0.0.0
                           dvametadata.framework   dvametadata   8.0.0.0
                           dvametadataapi.framework   dvametadataapi   8.0.0.0
                           dvametadataUI.framework   dvametadataUI   8.0.0.0
                           dvaplayer.framework   dvaplayer   8.0.0.0
                           dvatransport.framework   dvatransport   8.0.0.0
                           dvaui.framework   dvaui   8.0.0.0
                           dvaunittesting.framework   dvaunittesting   8.0.0.0
                           dynamiclink.framework   dynamiclink   8.0.0.0
                           ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                           ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                           ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                           LogSession.framework   LogSession   7.2.1.3600
                           mediacoreif.framework   mediacoreif   8.0.0.0
                           PlugPlugExternalObject.framework      6.0.0.96
                           PlugPlugOwl.framework   PlugPlugOwl   6.0.0.111
                           UpdaterNotifications.framework   UpdaterNotifications   9.0.0.3   "9.0.0.3"
                           WRServices.framework
                        Required plug-ins:
                           3D Studio 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Accented Edges 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Adaptive Wide Angle 16.0.1, Copyright © 2014-2015 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                           Angled Strokes 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Average 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “Average.plugin”
                           Bas Relief 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           BMP 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Camera Raw 9.3 (506), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Camera Raw Filter 9.3 (506), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Chalk & Charcoal 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Chrome 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Cineon 16.0.1  ©2002-2015 Adobe Systems Incorporated - from the file “Cineon.plugin”
                           Clouds 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Collada DAE 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Color Halftone 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Colored Pencil 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           CompuServe GIF 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Conté Crayon 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Craquelure 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crop and Straighten Photos 16.0.1  ©2003-2015 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                           Crop and Straighten Photos Filter 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Crosshatch 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crystallize 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Cutout 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Dark Strokes 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           De-Interlace 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dicom 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “dicom.plugin”
                           Difference Clouds 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Diffuse Glow 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Displace 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dry Brush 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Eazel Acquire 16.0.1  ©1997-2015 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                           Entropy 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Export Color Lookup Tables 16.0.1  �2012-2015 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                           Extrude 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           FastCore Routines 16.0.1  ©1990-2015 Adobe Systems Incorporated - from the file “FastCore.plugin”
                           Fibers 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Film Grain 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Filter Gallery 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Flash 3D 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Fresco 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glass 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glowing Edges 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Google Earth 4 KMZ 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Graphic Pen 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Halftone Pattern 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           HDRMergeUI 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                           HSB/HSL 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           IFF Format 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           IGES 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Ink Outlines 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           JPEG 2000 16.0.1  ©2001-2015 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                           Kurtosis 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Lens Blur 16.0.1, Copyright © 2002-2015 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                           Lens Correction 16.0.1, Copyright © 2002-2015 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                           Lens Flare 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Liquify 16.0.1, Copyright © 2001-2015 Adobe Systems Incorporated - from the file “Liquify.plugin”
                           Matlab Operation 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Maximum 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mean 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Measurement Core 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                           Median 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mezzotint 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Minimum 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           MMXCore Routines 16.0.1  ©1990-2015 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                           Mosaic Tiles 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Multiprocessor Support 16.0.1  ©1990-2015 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                           Neon Glow 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Note Paper 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           NTSC Colors 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                           Ocean Ripple 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           OpenEXR 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Paint Daubs 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Palette Knife 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Patchwork 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Paths to Illustrator 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           PCX 16.0.1  ©1989-2015 Adobe Systems Incorporated - from the file “PCX.plugin”
                           Photocopy 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Photoshop 3D Engine 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                           Photoshop Touch CC 2015 (16.0.1.0) ©1993-2015 Adobe Systems Incorporated - from the file “PSDX.plugin”
                           Picture Package Filter 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Pinch 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pixar 16.0.1  ©1989-2015 Adobe Systems Incorporated - from the file “Pixar.plugin”
                           Plaster 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Plastic Wrap 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PLY 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           PNG 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pointillize 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Polar Coordinates 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Portable Bit Map 16.0.1  ©1989-2015 Adobe Systems Incorporated - from the file “PBM.plugin”
                           Poster Edges 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PRC 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Radial Blur 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Radiance 16.0.1  ©2003-2015 Adobe Systems Incorporated - from the file “Radiance.plugin”
                           Range 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Render Color Lookup Grid 16.0.1  �2012-2015 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                           Reticulation 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Ripple 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Rough Pastels 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Save for Web 16.0.1, Copyright © 1999-2015 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                           ScriptingSupport 16.0.1, Copyright © 2015 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                           Shake Reduction 16.0.1, Copyright © 2014-2015 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                           Shear 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Skewness 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Smart Blur 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Smudge Stick 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Solarize 16.0.1  ©1993-2015 Adobe Systems Incorporated - from the file “Solarize.plugin”
                           Spaces 16.0.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
                           Spatter 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Spherize 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Sponge 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Sprayed Strokes 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stained Glass 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stamp 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Standard Deviation 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           STL 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Sumi-e 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Summation 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Targa 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Texturizer 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Tiles 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Torn Edges 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Twirl 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           U3D 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Underpainting 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Vanishing Point 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                           Variance 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Virtual Reality Modeling Language | VRML 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Water Paper 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Watercolor 16.0.1, Copyright © 1991-2015 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Wave 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wavefront|OBJ 16.0.1  ©2006-2015 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Wind 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wireless Bitmap 16.0.1  ©1989-2015 Adobe Systems Incorporated - from the file “WBMP.plugin”
                           ZigZag 16.0.1, Copyright © 2003-2015 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                        Optional and third party plug-ins:
                           Color Efex Pro 4 4.000, Copyright © 2000-2011 Nik Software Inc. - from the file “Color Efex Pro 4.plugin”
                           Nik Selective Tool 2.100, Copyright © 2000-2011 Nik Software Inc. - from the file “SelectivePalette.plugin”
                        Plug-ins that failed to load: NONE
                        Extensions:
                           Libraries, /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html
                           Adobe Color Themes, /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html
                           Export As, /Library/Application Support/Adobe/CEP/extensions/com.adobe.webpa.crema/PSPanel/dialog.html
                           Device Preview, /Library/Application Support/Adobe/CEP/extensions/com.adobe.preview/PSPanel/panel.html
                           Welcome, /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.photoshop.welcome/index.html
                           Share on Behance, /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.behance.shareonbehance.html/index.htm l
                           , /Library/Application Support/Adobe/CEP/extensions/com.adobe.preview/PSLoader/loader.html
                        Installed TWAIN devices: NONE
