2 Replies Latest reply: May 12, 2013 6:51 PM by SillyValley RSS
    Deskewing not working the same in version XI as it did in version 10
    lvldcty
      We have been having issues with Adobe XI and the de-skew feature.  In version 10 we could take a previously scanned PDF and go in to Tools > Documnet Processomg >Optimize Scanned PDF > make the needed changes to the Filters (Deskew:On, Background removal: Medium, Descreen: On, Text Sharpening: On) , Edit the OCR PDF output Style to "Searchable Image" and then run the optimization.  This would apply the filters and deskew the document both in the same step.  However, since version XI when we do the same thing, with the same files it will apply the filters but it will not deskew them (we have tried multiple files and multiple systems to rule out file issues and install issues).   The only way that we can get it to deskew it is to set the OCR PDF output to "Clearscan".  This would be fine except for the fact that the the clearscan setting does not apply the filters.  So...the only way we can get this to do what we need is to run the optimization once with the OCR PDF set to "Searchable Image" to apply the filters and then run it again with the OCR PDF output set to "clearscan" to deskew the document.  This is not a big deal with a single page document but becomes a larger time issue when dealing with large, multipage documents.  It appears that this is a "bug" in version XI.  Any suggestions on how to accomplish in version XI what we used to be able to do easily in Version X.
      Additional information: We are running Adobe 11.0.01 on Windows 7 64 bit OS.
      I have also seen LoriAUC's last post on http://forums.adobe.com/thread/992172 but those settings did not work for us either.
      Thanks in advance for any assistance.
