I create Webhelp output in RH9 with XP Blue skin. Primary viewing means are via IE where the Search panel functions fine. There are issues with the search panel when help is viewed in Safari on iPad. When search results populate the left panel, the length of the Search field and Go button in the panel expand right such that they are no longer visible. Some assumptions: (1) Text in the search results is forcing the expansion of the Search field/button as results fills up the space (characters from the results are cut off from view as well on right side of left panel). (2) This behavior is due to the frames associated with the Webhelp output.
Is anyone aware of a work around in RH9? I am not ready to upgrade to RH10, which I believe would potentially solve this and other issues related to output on Safari on iPad/Mac.
Note: I already have a fix for the partially hidden 'Search results per page' section in the second image thanks to the http://forums.adobe.com/message/2635086 posting.
IE example, no issue.
Safari on iPad example.
Regards,
Karen
Short of going to RH10 and using the new HTML5 Multiscreen SSLs, there is a hack you could try that changes the width of the left pane. Now I just need to remember what post it was...hmm... could be this one -
http://forums.adobe.com/message/2007076#2007076
or this one from Rick -
http://forums.adobe.com/message/3724614#3724614<http://forums.adobe.com/message/3724614
Thanks Jeff,
Your first link is an applicable post. As you hinted, it would involve changing some files behind the scenes which is not ideal.
The second post link is about hiding the dividing line between the TofC and topic areas, which doesn't apply to my case.
Karen
Good to hear - I squirrel little bits of knowledge away & then can't find it when required ;>)
