4 Replies Latest reply on Nov 15, 2007 9:14 AM by Newsgroup_User
    Disjoint Rollovers with Behaviors
      I am able to create a disjoint rollover. After rolling over a button symbol, I added a Swap Image behavior to load 2 different images to two different sliced areas of my canvas. When I mouseout from my button, I leave the images loaded . ( I do not swap them out.)
      With these new images loaded, I want to attach a new behavior to these images so that they load a website or new image into the slice in the area they are currently occupying or to the right of the slice they are in. Is this possible to do?
        • 1. Re: Disjoint Rollovers with Behaviors
          Level 7
          You want to load a website into the space occupied by a single slice?
          That would look pretty strange, don't you think?
          > currently occupying
          That you can do. Add the image to a new frame and make it swap in
          onMouseOut from the trigger image. You'll need to open the Behaviors
          panel and manually set the second swap image behavior to trigger onMouseOut
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: Disjoint Rollovers with Behaviors
            I have an image and several buttons on top of the image. on mouse over a button, I load 2 images from 2 different fireworks' frames to two areas of my canvas. ( This works) Now I try to mouse over the new images loaded and want to load a different frame into one of their locations. I was able to do this for one button.
            I want the same kind of scenario for all of the buttons I put on this image which is to load 2 different frames to different slices and then be able to click or mouse over the new data in the slices and load a new frame. If I try to do this for more than one button, it doesn't work. Any tips. I can send the fireworks file but am not sure if I can do that via the forum interface.
            • 3. Re: Disjoint Rollovers with Behaviors
              Level 7
              You are trying to get way too complex. Keep things simple for your
              viewers, or they won't be able to figure out how to use the page and
              will leave in frustration. Keep the file size of the page small, so it
              doesn't take the browser forever to load it.
              • 4. Re: Disjoint Rollovers with Behaviors
                Level 7
                Send it to me directly, at lightly@sc.rr.com, and I'll see what I can
                come up with.
