2 Replies Latest reply: Feb 27, 2013 8:37 AM by jjcarneiro RSS
    Is there a way to know if a file REALLY exists?
    jjcarneiro Community Member
      If a large file is being copied into a diretory. FileUtilService.Exists will return TRUE. That only indicates a 'directory entry' exists, not that the file is there and available.
      Is there a way to get that information? If you get Windows' file proeprties it will tell you that the file is 'locked', but I do not see any FileUtilService to get that info.
      Is there a solution to that?
      TIA
      julio
        • 1. Re: Is there a way to know if a file REALLY exists?
          Steve Bishop Community Member
          Possibly you could do it in an Execute Script step using methods available on the Java File object.
          • 2. Re: Is there a way to know if a file REALLY exists?
            Hi Steve,
            That is exactly what I ended up doing.
            For future reference here is the script code I used, seems to do the job:
            File filename =pathToFile( patExecContext.getProcessDataStringValue("/process_data/@filepath"));
            boolean doesFileReallyExists = filename.canWrite();
            if (doesFileReallyExists ) {
                        try {
                            ran = new RandomAccessFile(filename , "rw");
                             try {
                                if (ran != null) ran.close();
                             }  catch (IOException ioe) {
                        } catch (Exception ex) {
                            doesFileReallyExists = false;
            patExecContext.setProcessDataBooleanValue("/process_data/@fileExists", doesFileReallyExists );
            One caveat of that script is that LCES needs R/W access to the file/document.
            hth
            julio
