2 Replies Latest reply on Apr 5, 2013 2:59 PM by BobM1990
    Colour profiles etc. workspace & pdf
    BobM1990
      Hi there
      I know that there will always be a difference between onscreen and printed results. Although I would like to know what are the best settings to avoid a huge difference between the bright and colourful colours I get in InDesign when working on the file, and the final result CMYK-pdf that goes to the printing company? Sometimes difference is so big...
      Are there special Adobe (or other) tools to avoid this huge difference between InDesign workspace colours and CMYK-PDF?
      And is it recommended to use for example the ColorMunki calibration for a MacBook Pro?
      Thanks a lot!
      Bob
        • 1. Re: Colour profiles etc. workspace & pdf
          Hardware monitor profiling will help with overall display and soft proofing accuracy, but won't change the realities of color gamuts. If you are choosing out-of-gamut RGB or Lab colors they will have to change when they are converted to CMYK values.
          If you want to work with RGB colors it's a good idea to turn on Overprint or Separation Preview while you work, which will preview the eventual conversion to your document's CMYK space. The document's profile (Edit>Assign Profiles...)  should be the correct profile for the destination press—the CMYK profile affects the softproof accuracy.
          RGB also has a gamut limit—100% cyan cannot be accurately displayed, so some CMYK blues will print with more saturation than a soft proof even on a well calibrated display.
          • 2. Re: Colour profiles etc. workspace & pdf
            BobM1990 Level 1
            Okay I guess this will do Thanks for your kind help and support!
