2 Replies Latest reply on Feb 27, 2013 1:54 PM by Mandy_Wiesener
      • 1. Re: copy two rich textboxes in to one
        Jonathan Stephenson Level 1
        2 or more textboxes if poss?
        • 2. Re: copy two rich textboxes in to one
          Mandy_Wiesener
          I'm not sure if I understand you.
          The content from two or more fields to copy into one filed ist not so difficult.
          • Copy the following script in the calculate-Event from the targetfield.
          • You can connect fieldentries with +
          • If you want to connect with a static string you can use "here comes your static text"
          • You can also use the script in the exit-Event of the surname- and birthplace- and/or  birthdate-field.
          if(surname.rawValue == null || birthplace.rawValue == null || birthdate.rawValue == null)
          }else
              this.rawValue = surname.rawValue + " born in: " + birthplace.rawValue + " born at: " + birthdate.rawValue;
              //this.rawValue = surname.rawValue + ", " + birthdate.rawValue;
          I hope it was helpull for you,
          Mandy
