3 Replies Latest reply on Feb 26, 2013 1:17 PM by ssprengel
    CR2 to jpg ..... in CS4
    will not let me enter any
      How & Where to get a copy of the plug-in required to convert CR2 files from my new Canon 5D M III to JPG in CS4?
      .... and please dont suggest I update to CS6.
        • 1. Re: CR2 to jpg ..... in CS4
          R_Kelly Adobe Community Professional
          Unfortunatly cs4 does not support the required camera raw plugin 6.7 that you would need.
          Photoshop cs4 only supports up to the camera raw 5.7 plugin.
          Two alternatives would be using the 7.3 DNG Converter to convert your files to dng copies which then photoshop cs4 could convert to jpegs or using the canon
          software to convert the camera raw files to jpegs or tiffs if you want to edit them in photoshop before saving as jpegs.
          What operating system are you using?
          • 2. Re: CR2 to jpg ..... in CS4
            kendallplant Adobe Employee
            Thread moved from PS Beginners forum to Camera Raw fourm.
            • 3. Re: CR2 to jpg ..... in CS4
              ssprengel Adobe Community Professional & MVP
              In lieu of upgrading Photoshop to the current version, you could also get the current version of Lightroom 4.3 which is much cheaper than Photoshop, and use that as the raw-adjustment front end to the older Photoshop, via LR’s Edit in Photoshop with Lightroom Adjustments.  You would want to try the Trial version of LR to make sure it can run well enough on your  computer.
