2 Replies Latest reply on Feb 28, 2013 4:31 PM by K J 27
    PSE 10 Organizer zapped by power outage
    K J 27
      There was a major power outage while I was exporting files from Organizer 10.  Now when I try to open Organizer, it opens momentarily, and then a a notice pops up that says:  "Elements 10 has topped working.  A problem caused the program to stop working correctly.  Windows will close the program and notify you if a solution is available."  Obviously, Windows hasn't found a solution.  I can still get into Elements Editor, but I do use Organizer for all of my organizing activities.  Is there a way that I can repair PSE/Organizer program files without uninstalling the entire program and then reinstalling?  Also if I have to do that, will I have difficulties deactivating and reactivating PSE? I'm using a Windows 7 machine with 12 GB Ram.  Thanks for any info you can provide.
        • 1. Re: PSE 10 Organizer zapped by power outage
          andaleebfatima1 Adobe Employee
          -Kill any such exe from the task manger, if running-
          autoanalyzer, photoshop file agent, dynamic link manager, photoshop server and photoshopelementsorganizer.exe
          -Go to %appdata%\adobe\elements organizer\11.0\organizer and delete the files psa.prf and status.dat
          -Now please try launching Organizer directly from its exe in C:\Program Files (x86)\Adobe\Elements 11 Organizer by right click >> Run As Admin keeping Shift key pressed. You should see Catalog Manager dialog. Create a new catalog and try.
          Andaleeb
          • 2. Re: PSE 10 Organizer zapped by power outage
            K J 27 Level 1
            Thank you very much for your assistance.  It was very helpful.  I was able to get into the catalog manager and establish a new catalog through which I could get into my original catalog.  I was still not able to get into my original main catalog directly, however, and I got another suggestion from MichelBParis to work with the catalog pse10db file in the “catalog” folder, and that did the trick.  Again, however, your suggestion was very helpful.
