6 Replies Latest reply on May 9, 2013 8:34 AM by Ashif_22khan
    broseForDirectory() crashes Indesign.
    Ashif_22khan
      Hi All,
      when i am trying to call browseForDirectory() method from my extension it carshes the indesign, I am a newbee in extension development, please suggest.
      I am also handling select and cancle events in my code. for reference i am also posting the code that i am using to do that.
        var cFileReference:File = File.desktopDirectory;
                                              cFileReference.browseForDirectory(File.desktopDirectory.nativePath);
                                              cFileReference.addEventListener(Event.SELECT,fileReferenceSelect);
                                              cFileReference.addEventListener(Event.CANCEL,fileReferenceCancel);
      Ashif
        • 1. Re: broseForDirectory() crashes Indesign.
          Harbs. Level 6
          This is  a known bug. I use the ExtendScript file browsing functionality as a workaround. (Folder.selectDialog())
          Harbs
          • 2. Re: broseForDirectory() crashes Indesign.
            Ashif_22khan Level 1
            @Habs
            Can you please explain how to do that?
            • 3. Re: broseForDirectory() crashes Indesign.
              Harbs. Level 6
              Create an ExtendScript function like this:
              function browseForDirectory(title){
                   var f = Folder.selectDialog(title);
                   if(!f){
                        return "";
                   if(File.fs == "Macintosh"){
                        return f.absoluteURI;
                   } else {
                        return f.fsName;
              From ActionScript you do this:
              var filePath:String = jsxInterface.browseForDirectory("Gimme some folder, dude!");
              if(filePath){
                   var myFolder:File = new File(filePath);
                   // go mess with the folder...
              • 4. Re: broseForDirectory() crashes Indesign.
                @Harbs
                Thanks alot.
                • 5. Re: broseForDirectory() crashes Indesign.
                  kc2scy
                  Hi Harps,
                  this is interesting. were do you place the extend script file?
                  within the scipt folder or is t part of plug-in package.
                  • 6. Re: broseForDirectory() crashes Indesign.
                    @kc2scy
                    You have to place your jsx file inside the resource of your app.
                    here is a sample
                    [Embed (source= "Resources/Browse.jsx" , mimeType= "application/octet-stream" )]
                                        private static var myScriptClass:Class;
                                        public static function runTwo():String {
                                                  var jInterface:HostObject = HostObject.getRoot(HostObject.extensions[0]);
                                                  var path:String="";
                                                  try{
                                                            var path:String=jInterface.eval( new myScriptClass().toString());
                                                  }catch(e){
                                                            return "";
                                                  return path;
