3 Replies Latest reply on Feb 26, 2013 6:10 AM by Peter Kahrel
    Read text from document line by line
    SimonLinden
      I have some text that I want to manipulate either in InDesign or before placing it in InDesign. I know how to do GREP search/find from the script but now I need to read the text into the document to do things I don't think I can do with GREP. So the short question is how to get external text into a string that I can loop over and make changes to with other script functions, preferably line by line.
      This should show how I'm thinking:
      grepFind("(^.+)") = curString;
      function grepFind(find){
          app.findGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences.findWhat = find;
          //return found text
      I'm providing the full background just in case someone has suggestions on how to do this more efficiently:
      I have many textdocuments that are ordered like this:
      a ...[some random text]
      b ...
      c ...
      a ...
      b ...
      a ...
      Each instance of 'a' signifies a new chapter and each new line after that is a new verse in that chapter (until we reach the next 'a'). So the example above I'd like to change to:
      1:1 ...
      1:2 ...
      1:3 ...
      2:1 ...
      2:2 ...
      3:1 ...
      To automate this I need variables that increase with every found instance of a pattern - to my knowledge this can't be done with GREP?
        • 1. Re: Read text from document line by line
          Peter Kahrel Adobe Community Professional & MVP
          I would use paragraph numbering, then maybe a Find/Change query to apply the paragraph styles. Something like this:
          1. Create a paragraph style, named e.g. chapter and verse. Enable paragraph numbering, set the level to 2, and use ^1.^#.^t as the number.
          2. Apply this paragraph style to all lines that start with a chapter or a verse number.
          You'll see that everything is now numbered as if you had just one chapter. That's because the chapter number changes only if you insert a paragraph of level 1. You don't use those, but you have to have them, so you insert them and you hide them:
          3. Create a paragraph style, named e.g. chapter. Enable paragraph numbering, set the level to 1, use ^1 as the number string. Set the leading to 0 and the character colour to None.
          4. Insert a blank line before all paragraphs that start with a, and apply the chapter paragraph style to those blank lines. Two simple grep replacements do the job:
          a. Find what: (?<=\r)a
          b. Replace with: @@@@\ra
          a. Find what: @@@@
          b. Replace with: <nothing>
          c. Change format: par. style chapter
          Peter
          • 2. Re: Read text from document line by line
            SimonLinden Level 1
            That's a clever solution. Didn't realize you could use numbered lists like that.
            Is there a way to "apply" this formatting so that the numbers are a real part of the text?
            • 3. Re: Read text from document line by line
              The only thing I can think of is to convert the numbers to text. In the UI you'd use Type > Bulleted and numbered lists > Convert . . . to text. In a script you would use the paragraph's bulletsAndNumberingResultText property.
