11 Replies Latest reply on Jun 6, 2013 6:07 AM by AmintaAdobe
    Tables in Edge?
    pmfr01 Level 2
      Hi there.
      Is there a way to do tables in Edge?... With the html tags, that is?
      pmfr
        • 1. Re: Tables in Edge?
          joel_pau Level 5
          This code will return a table:
          var myTable = '<table border="1">'
                   +'<tr>'
                   +'<th>Header 1</th>'
                   +'<th>Header 2</th>'
                   +'</tr>'
                   +'<tr>'
                   +'<td>row 1, cell 1</td>'
                   +'<td>row 1, cell 2</td>'
                   +'</tr>'
                   +'<tr>'
                   +'<td>row 2, cell 1</td>'
                   +'<td>row 2, cell 2</td>'
                   +'</tr>'
                   +'</table>';
                   sym.$("Text").html(myTable);
          • 2. Re: Tables in Edge?
            resdesign Adobe Community Professional & MVP
            NIce, Joel!
            • 3. Re: Tables in Edge?
              pmfr01 Level 2
              I was doing it without setting a variable - sym.$('table_container_1').html('<table summary="My tabel"><thead align="center" valign="center"><tr><th>Header 1</></><tr><th>... - your method is much better.
              Thanx Joel!
              pmfr
              • 4. Re: Tables in Edge?
                joel_pau Level 5
                You can also format cells adding these lines after sym.$("Text").html(myTable):
                sym.$("th").css({"border-width":"2px", "padding":"1px", "text-align":"center", "background-color":"#355d48",
                                              "color":"#ffffff", "font":"bold 20px Tahoma, Geneva, sans-serif"});
                sym.$("td").css({"border-width":"2px", "padding":"1px", "text-align":"left", "background-color":"#DEE8DC",
                                              "color":"#355d48", "font":"bold 18px Tahoma, Geneva, sans-serif"});
                Or you can use classes:
                         +'<tr>'
                         +'<th class="header">Header 1</th>'
                         +'<th class="header>Header 2</th>'
                         +'</tr>'
                         +'<tr>'
                         +'<td class="cell">row 1, cell 1</td>'
                         +'<td class="cell">row 1, cell 2</td>'
                         +'</tr>'
                         +'<tr>'
                         +'<td class="cell">row 2, cell 1</td>'
                         +'<td class="cell">row 2, cell 2</td>'
                         +'</tr>'
                         +'</table>';
                sym.$(".header").css({"border-width":"2px", "padding":"1px", "text-align":"center", "background-color":"#355d48",
                sym.$(".cell").css({"border-width":"2px", "padding":"1px", "text-align":"left", "background-color":"#DEE8DC",
                • 5. Re: Tables in Edge?
                  pmfr01 Level 2
                  Awesome.
                  Thanx again Joel.
                  pmfr
                  • 6. Re: Tables in Edge?
                    Lloydie73 Level 1
                    Hi Joel,
                    this makes sense, albeit time-consuming in reformatting. so then with this code, declare it where? inside the sybol where one would want the table? on the stage? composition?
                    • 7. Re: Tables in Edge?
                      joel_pau Level 5
                      Hi Lloydie73,
                      If you declare correctly, you can script your table anywhere.
                      Well, you can upload your file using a private message.
                      I will look at your file.
                      See you soon.
                      • 8. Re: Tables in Edge?
                        Lloydie73 Level 1
                        thank you Joel - you're well-worded response got me thinking the correct way!
                        regards,
                        • 9. Re: Tables in Edge?
                          AmintaAdobe Level 1
                          Hi Joel!
                          Welcome back! I've sent you a pm in march about dinamically update the content of a tabel in AE, did you read it?
                          Thanks!
                          Davide
                          • 10. Re: Tables in Edge?
                            joel_pau Level 5
                            Hi Davide,
                            Could you resend me your message?
                            • 11. Re: Tables in Edge?
                              AmintaAdobe Level 1
                              Ok!
