3 Replies Latest reply on Mar 7, 2013 11:24 PM by 5898845
    Scout overhead
    5898845
      Hi guys,
      I'm wondering how much overhead one could expect from using Scout when profiling an application.
      The CPU usage Scout reports fo our Starling based applicaiton is very high, about 94% and I simply can't imagine that our applciation actually requires this much CPU time.
      Sure, Starling itself is quite heavy on the CPU, this seems way too high, though.
      Does anyone have an idea how much CPU the enabled telemetry itself requires? Would be nice to get an approximate number of how much we can subtract from the reported 94%.
      Any insight would be highly appreciated.
      Cheers guys!
        • 1. Re: Scout overhead
          5898845 Level 1
          No one? I can't image that not even the guys at Adobe know this?
          • 2. Re: Scout overhead
            Michael J.A. Smith Adobe Employee
            If you only use the low overhead settings (Basic Telemetry, ActionScript Sampler, and CPU Usage), then the overhead of running Scout should be negligible. I'm assuming you don't have Stage3D Recording turned on - if you do, you should turn it off to measure performance.
            After doing this, if Scout is showing most of the time spent in ActionScript or Rendering, then you can be certain that it's your content that's slow. Any overhead that's due to profiling would appear as part of the "Other" category.
            The CPU usage reported by Scout is for Flash Player as a whole - if you're running your app in the browser, make sure there isn't other Flash content running, as this will contribute to the CPU usage. If you're seeing high CPU usage and most of the time is spent in ActionScript, you can use the ActionScript panel to see which functions are the most expensive. There's a lot of good advice on the Starling forums about how to optimise your content, and avoid common pitfalls.
            Also, please make sure that you have hardware acceleration enabled - if Flash has to use software rendering, then the performance will be terrible. You can check in the Session Info panel in Scout - if it's using sofware rendering, then you'll see something along the lines of "Software Hw_disabled" in the 3D Driver Info field.
            • 3. Re: Scout overhead
              5898845 Level 1
              Thank you very much for your detailed answer Michael!
              That was very helpful indeed.
              BTW: I'm running the app on an iPad with the latest version of AIR.
