3 Replies Latest reply on Mar 4, 2013 12:07 PM by TimJaramillo
    Constant random X & Y movement + constraints?
    GeminiStarII
           Hello Everyone I am new to Adobe Edge and on top of that have no experience with java script and I am ratter poor with code in general. I personally could not find anything similar enough to reverse engineer although that might be due to the above stated reasons.   I want to thank everyone in advance for their help.
           Now what I wanted to know is I have a symbol I want to slowly drift around the screen in in random X and Y Directions. It should be constantly moving and periodically change direction randomly. The other problem is I want to constrain the symbol so it can’t get any closer than 100 pixels away from the all edges of the screen.*Note* I have no even semi working code not for lack of trying I just don’t know what I am doing..?
        • 1. Re: Constant random X & Y movement + constraints?
          TimJaramillo Level 4
          Hi Gemini,
          Here is an example of an object animating randomly around the screen at random intervals.
          Example:
          http://www.timjaramillo.com/code/edge/random_tween_screen/
          Source:
          http://www.timjaramillo.com/code/edge/_source/random_tween_screen.zip
          Here is the code on Stage.compositionReady:
          // center Stage
          $("#Stage").css("margin","auto");
          // timer
          var timerTween;
          // used to offset the bounds
          var objWidth = sym.$("face").width();
          var objHeight = sym.$("face").height();
          // stage width/height
          var windowWidth = 700;
          var windowHeight = 600;
          // min/max vars
          var minXPos = 100;
          var minYPos = 100;
          var maxXPos = windowWidth-objWidth-100;
          var maxYPos = windowHeight-objHeight-100;
          // timer function
          sym.initTimer = function(){
                    // very short timer, to call "tweenObject" function
                    timerTween = setTimeout(function() {
                         sym.tweenObject();
                                  }, 10);
          // here's where we get random values and actually tween the object, using the jQuery "animate" method
          sym.tweenObject = function(){
                    var tweenTime = sym.getRandomInRange(2000, 5000);
               var xPos = sym.getRandomInRange(minXPos, maxXPos);
               var yPos = sym.getRandomInRange(minYPos, maxYPos);
               sym.$("face").animate({left:xPos, top:yPos}, tweenTime, 'swing', sym.initTimer);
          // utility function to give us random values
          sym.getRandomInRange = function(start, end) {
               return Math.round( start + (Math.random() * (end - start)) );
          // let's start the animation, shall we?
          sym.initTimer();
          • 2. Re: Constant random X & Y movement + constraints?
            GeminiStarII Level 1
            Thank you for your help I am slowly starting to understand the code. How could I use it with multiple symbols? I have managed to get it to work but all with problems.
            1 all symbols move to the exact same location.
            2 The symbols all move in random directions but ignore the constraints and float of the screen.
            3 The symbols obey the constraints and move randomly without over lapping but stick towards the upper left corner of the stage.
            What method would you use to work the code on multiple symbols?
            • 3. Re: Constant random X & Y movement + constraints?
              Hi Gemini, you can animate multiple symbols using the same code with just a few tweaks.
              Example:
              www.timjaramillo.com/code/edge/random_tween_multipleObj
              Source:
              www.timjaramillo.com/code/edge/_source/random_tween_multipleObj.zip
              Code on Stage.compositionReady:
              // center Edge content
              var timerTween;
              /* actual browser window
              var windowWidth = window.innerWidth;
              var windowHeight = window.innerHeight;
              var stageWidth = $("#Stage").width();//700;
              var stageHeight = $("#Stage").height();
              var objWidth = sym.$("obj_1").width();
              var objHeight = sym.$("obj_1").height();
              var minXPos = 100;
              var minYPos = 100;
              var maxXPos = stageWidth-objWidth-100;
              var maxYPos = stageHeight-objHeight-100;
              sym.initTimer = function(id){
              sym.tweenObject(id);
              }, 10);
              sym.tweenObject = function(id){
              sym.$("obj_"+id).animate({left:xPos, top:yPos}, tweenTime, 'swing', sym.initTimer(id) );
              // start animation
              sym.initTimer(1);
              sym.initTimer(2);
              sym.initTimer(3);
              sym.initTimer(4);
