4 Replies Latest reply on Feb 27, 2013 3:17 AM by bacas_christy
    Fit anchored frames to content
    bacas_christy
      Hi All,
      I am adding some text into an anchored textframe and placed in the same location using Indesign javascript.
      But I am unable to fit the anchored text frame to content.
      Below I have pasted the source code.
      try
         for (i = 0; i < myFound.length; i++)
      var myInsertionPoint = myFound[i].insertionPoints[-1];
      var myAnchoredFrame = myInsertionPoint.textFrames.add();
      myAnchoredFrame.contents = "This is an anchored frame.";
      myAnchoredFrame.fit(FitOptions.FRAME_TO_CONTENT);
      with(myAnchoredFrame.anchoredObjectSettings)
        anchoredPosition = AnchorPosition.anchored;
        anchorPoint = AnchorPoint.topLeftAnchor;
        horizontalReferencePoint = AnchoredRelativeTo.anchorLocation;
        horizontalAlignment = HorizontalAlignment.leftAlign;
        anchorXoffset = 72;
        verticalReferencePoint = VerticallyRelativeTo.lineBaseline;
        anchorYoffset = 24;
        anchorSpaceAbove = 24;
      catch (e) {alert (e.message)}
      Please help me out.
      Thanks in advance,
      Christy
        • 1. Re: Fit anchored frames to content
          -hans- Level 4
          ... cause your in overset from the start. try to give some bounds, so that at least the first words fit
          var myInsertionPoint = app.activeDocument.stories[0].insertionPoints[-1];
          var myAnchoredFrame = myInsertionPoint.textFrames.add(undefined, undefined, undefined,{geometricBounds: [0,0,50,50]});
          Edit: You'll still have to check for overflows after fitting and in case expand bounds and fit again. It's bit of buggy also in the GUI.
          Hope this'll help
          Hans-Gerd Claßen
          • 2. Re: Fit anchored frames to content
            bacas_christy Level 1
            Hi Hans,
            If I add the bounds its throwing some error like
            "Invalid Object for this request".
            Here the portion of code I have updated:
            var myFound = myDoc.findGrep (true);
            try
            Please advice.
            Christy
            • 3. Re: Fit anchored frames to content
              -hans- Level 4
              your changing the story by adding a textFrame, so your reference myFound[i] is actually not valid after the first loop.
              So, loop backwards when changing / deleting something: while(i--) ... or for (i < myFound.length, i >= 0; i--)
              Another reason could be that a reference itsself is in overset when accessed.
              Hope this'll help
              • 4. Re: Fit anchored frames to content
                Dear Hans,
                Thanks for your response and it is working fine.
                Thanks again,
                Christy
