1. Re: Photoshop CS6 Stopped Working (possible solution)
rsukhram@tgioa.com Feb 27, 2013 7:16 AM (in response to rsukhram@tgioa.com)So it seems to be the font management suite Extensis Suitcase that is causing my problem. After adding back only their extension the problem came back again. Removing it fixes my issue.
2. Re: Photoshop CS6 Stopped Working (possible solution)
Noel Carboni Feb 27, 2013 7:44 AM (in response to rsukhram@tgioa.com)Thank you for your post. I'm sure it will help others, especially the mention that some files may be left in your Plug-ins subfolder even if all plug-ins are removed via their installers.
We have occasionally seen others report here that Extensis Suitcase Fusion has caused some problems as well. You should report the issue to them and see if they have (or have plans to release) a version that solves the crash.
-Noel
3. Re: Photoshop CS6 Stopped Working (possible solution)
rsukhram@tgioa.com Feb 27, 2013 8:02 AM (in response to Noel Carboni)Hey Noel I opened a ticket with Extensis to see what they suggest. Do you have any recomendations on a better font management utility?
4. Re: Photoshop CS6 Stopped Working (possible solution)
Noel Carboni Feb 27, 2013 4:08 PM (in response to rsukhram@tgioa.com)I'm the wrong person to ask. I do more photo editing than designs with text, so I have one relatively small list of fonts.
What does it do that's bad if you have a lot of fonts at once in one big list?
-Noel
