3 Replies Latest reply on Feb 27, 2013 3:26 PM by Liam Dilley
    Complex forms with images
    jefferis Level 1
      I have a client who needs to upload larger images or CAD designs.  Is there any problem or limitation with allowing these uploads via BC ?
      Also, the form's I've created for him are very complex....   user selected details like ring size, shank size, cut, etc.  using mm  and carats.
      1. I created these in DW.  Is there a way to at least use the form layout or is necessary to  use the BC forms in order to integrate with the BC databases?
      2. He has one form area restricted for dealers only and one for consumers,  I assume it is possible to restrict areas of the website to logged in dealers vs. logged in customers?
      3. I have developed the restricted users and consumers databases on his existing host, which I could still use if I had to.
      Jeff
        • 1. Re: Complex forms with images
          Liam Dilley Adobe Community Professional & MVP
          - File size limits are 100mb per file.
          - Not sure what you meaning in regards to forms you can make as you need to.
          - You can create login securezones and pages with content such as forms if you need to
          - To use the Database on another system with BC you will have to use API, or export it and import it into the BC site.
          • 2. Re: Complex forms with images
            jefferis Level 1
            I mean if I have a form already constructed,  there is no way to simply import it from an old site into BC, right?  I'm thinking the database   field names would not correspond to the BC database.  I was just wondering if the field design could be used or if I have to start from scratch..
            • 3. Re: Complex forms with images
              No, you need to rebuild the form in your BC site. You can keep the layout as long as you update the form action ID and any custom field ID's need to be updated to relate to their database equivelent.
