2 Replies Latest reply on Feb 27, 2013 2:47 PM by mixedherbs
    define variables in
    mixedherbs
      Hi guys,
      A really simple question probably :-)
      I'm using Flash MX 2004 Pro , AS2
      There is a name variable which will be taken from an input text field.
      Trying to use "for" to take the lenght of the name and store every
      letter in a variable. All this within the "for".
      letter0=J
      letter1=o
      letter2=n
      etc.
      the script:
      thename = "Jonathan";
      for (i=0; i<thename.length; i++) {
                "letter"+i = thename.charAt(i);
      Gives me an error at compiling:
      **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 4: Identifier expected
                     var "letter"+i = thename.charAt(i);
      Total ActionScript Errors: 1            Reported Errors: 1
      How could I do this?
        • 1. Re: define variables in
          Nabren Level 3
          You can use an object:
          var letterObject:Object = new Object();
            letterObject["letter"+i] = thename.charAt(i);
          You can then access it later by letterObject.letter0 or letterObject["letter0"] (the latter is better for iterations because you can't go letterObject.letter<variableName> expecting it to replace the number for you)
          EDIT:
          You can also use the this object:
            this["letter"+i] = thename.charAt(i);
          then you would just access by this.letter0 or this["letter0"] or just by plain old letter0
          • 2. Re: define variables in
            mixedherbs Level 1
            Thank you Nabren, success!!!
