2 Replies Latest reply on Feb 28, 2013 8:47 AM by Luke Hodsdon
    [AS] Moving copied text to the end of a Text frame with Applescript?
    Luke Hodsdon
      I'm trying to run an IF statement that eventually will check for 3 wild card characters (@,—," - ") and then copy that paragraph information into the end of another textbox that my script is also creating.
      Here's a snippet of what i'm stuck on...
      tell application "Adobe InDesign CS5"
                repeat with i from 1 to (count of paragraphs)
                          try
                                    tell paragraph i
                                              set ThePage to my get_CurrentPage()
                                              try
        (*Check for wildcard " - "*)
                                                        if it contains " – " then
        set applied paragraph style to "AD SIZE"
        set Ad_Size to contents
        set {This_Width, This_Height} to {"", ""}
        repeat with This_Ad in Ad_Props
        if Ad_Size contains (Ad_Label of This_Ad) then
        set This_Width to Ad_Width of This_Ad
        set This_Height to Ad_Height of This_Ad
        exit repeat
        end if
        end repeat
        set Ad_Box to my Make_Box(ThePage, {1.875, 10.875, This_Height + 1.875, This_Width + 10.875})
        duplicate contents to (insertion point -1 of Ad_Box)
        (*Check for wildcard "—"*)
                                                        else if it contains "—" then
        set applied paragraph style to "AD REP"
        (*Check for wildcard "©"*)
                                                        else if it starts with "©" then
        set applied paragraph style to "AD PLACEMENT"
        delete (character 1)
                                                        else
                                                        end if
                                              end try
                                    end tell
                          on error errmsg number errnum
                                    display dialog "There has been an error " & "[" & i & "] (" & errmsg & " [" & errnum & "])" buttons {"Okay"} default button 1 with icon stop
                          end try
                end repeat
      end tell
      The whole script makes the boxes like I need, but it's not moving the content to the Ad_Box. I think the problem is here:
      But I can't figure out the right script. Racking my brain all day. Any help would be greatly appreciated!!
      Here's a block of text i'm using this with if it helps to visualize it:
      1/4 –
      Ad Name
      P/U—SW
      ©12
      FULL –
      Ad Name
      C/R—SW
      ©9
      FULL –
      Ad Name
      C/R—SW
      ©5
      Message was edited by: Luke Hodsdon (fixed coding & spelling mistakes)
