2 Replies Latest reply on Feb 28, 2013 11:06 AM by kcelsi
    Creating a Survey - Novice Question
    kcelsi Level 1
      Hello,
      I am extrememely new to Javascript.  I have been doing some research online and copy/pasting code to create the results I need.  I am trying to create an online survey in which users select buttons to answer questions and then the total results appear at the bottom of the survey.  So far this is what I have:
      http://sicolaconsulting.com/SurveyTest4.php
      The problem I have with this is that on each line, a user can select more than one box.  I don't want this so I thought radio buttons would be better.  I then came up with this:
      http://sicolaconsulting.com/SurveyTest3.php
      The problem with this is that with the function I am using, I can only get it to display the value of the first line.  I need it to calculate the sum of all the lines.
      Can you help me revise the script I have to get my desired result.
      Here is my code for the first page, followed by the code for the second page.  THANK YOU!
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      <title>Survey</title>
      <style type="text/css">
      body,td,th {
                font-family: Tahoma, Geneva, sans-serif;
      </style>
      <link href="stylesheets/SCG_Styles.css" rel="stylesheet" type="text/css" />
                function TotalPart1A() {
                          document.survey.Total1A.value = '';
                          var sum = 0;
                          for (i=0;i<document.survey.Part1A.length;i++) {
                            if (document.survey.Part1A[i].checked) {
                                      sum = sum + parseInt(document.survey.Part1A[i].value);
                          document.survey.Total1A.value = sum;
      </script>
      </head>
      <body>
      <div id="wrapper"><br />
        <div id="survey-header"><strong>Purpose:</strong><br />
          The Learning Style Survey assesses your general approach to learning. <br />
          It does not predict your behavior, but it is a clear indication of your overall style preferences.<br />
          <br />
          <strong>Instructions:</strong><br />
          For each item circle the response that represents your approach. Complete all items. <br />
          There are eleven major activities representing twelve different aspects of your learning style. <br />
          When you read the statements, try to think about what you generally do when learning. <br />
          <br />
          <strong>Time:</strong><br />
          It takes about 30 minutes to complete the survey. Do not spend too much time on any item. Indicate your immediate response (or feeling) and move on to the next item. <br />
          <br />
          <strong>For each item, enter your immediate response:<br />
            0 = Never  1 = Rarely  2 = Sometimes  3 = Often  4 = Always</strong><br />
        </div>
                <div id="survey">
      <form name="survey">
                <div id="survey-section1">
                      <table class="survey-table" cellspacing="0" width="812">
                        <tr>
                          <td height="24" colspan="2" align="left" bgcolor="#CCCCCC"><strong>Part 1: How I Use My Physical Senses</strong></td>
                          <td height="24" align="center" bgcolor="#CCCCCC"><strong>1</strong></td>
                          <td height="24" align="center" bgcolor="#CCCCCC"><strong>2</strong></td>
                          <td height="24" align="center" bgcolor="#CCCCCC"><strong>3</strong></td>
                          <td height="24" align="center" bgcolor="#CCCCCC"><strong>4</strong></td>
                          </tr>
                        <tr>
                          <td width="31" height="27">1</td>
                          <td width="515" align="left">I remember something better if I write it down.</td>
                          <td width="60"><input type="checkbox" name="Part1A" value="1" onchange="TotalPart1A()"/></td>
                          <td width="60"><input type="checkbox" name="Part1A" value="2" onchange="TotalPart1A()"/></td>
                          <td width="60"><input type="checkbox" name="Part1A" value="3" onchange="TotalPart1A()"/></td>
                          <td width="60"><input type="checkbox" name="Part1A" value="4" onchange="TotalPart1A()"/></td>
                          </tr>
                        <tr>
                          <td width="31" bgcolor="#EAEAEA">2</td>
                          <td height="27" align="left" bgcolor="#EAEAEA"> I take detailed notes during lectures.</td>
                          <td bgcolor="#EAEAEA"><input type="checkbox" name="Part1A" value="1" onchange="TotalPart1A()"/></td>
                          <td bgcolor="#EAEAEA"><input type="checkbox" name="Part1A" value="2" onchange="TotalPart1A()"/></td>
                          <td bgcolor="#EAEAEA"><input type="checkbox" name="Part1A" value="3" onchange="TotalPart1A()"/></td>
                          <td bgcolor="#EAEAEA"><input type="checkbox" name="Part1A" value="4" onchange="TotalPart1A()"/></td>
                          </tr>
                        <tr>
                          <td>3</td>
                          <td height="27" align="left">When I listen, I visualize pictures, numbers, or words in my head.</td>
                          <td><input type="checkbox" name="Part1A" value="1" onchange="TotalPart1A()"/></td>
                          <td><input type="checkbox" name="Part1A" value="2" onchange="TotalPart1A()"/></td>
                          <td><input type="checkbox" name="Part1A" value="3" onchange="TotalPart1A()"/></td>
                          <td><input type="checkbox" name="Part1A" value="4" onchange="TotalPart1A()"/></td>
                          </tr>
                        <tr>
                          <td bgcolor="#EAEAEA">4</td>
                          <td height="27" align="left" bgcolor="#EAEAEA"> I prefer to learn with TV or video rather than other media. </td>
                          </tr>
                        <tr>
                          <td>5</td>
                          <td height="27" align="left"> I use color coding to help me as I learn to work.</td>
                          </tr>
                        <tr>
                          <td bgcolor="#EAEAEA">6</td>
                          <td height="27" align="left" bgcolor="#EAEAEA"> I need written directions for tasks.</td>
                          </tr>
                        <tr>
                          <td>7</td>
                          <td height="27" align="left"> I have to look at people to understand what they say.</td>
                          </tr>
                        <tr>
                          <td bgcolor="#EAEAEA">8</td>
                          <td height="27" align="left" bgcolor="#EAEAEA">I understand lecturers better when they write on the board.</td>
                          </tr>
                        <tr>
                          <td>9</td>
                          <td height="27" align="left">Charts, diagrams, and maps help me understand what someone says. </td>
                          </tr>
                        <tr>
                          <td bgcolor="#EAEAEA">10</td>
                          <td height="27" align="left" bgcolor="#EAEAEA">I remember people’s faces, but not their names. </td>
                          </tr>
                        <tr>
                          <td> </td>
                          <td height="27" align="right">A TOTAL: </td>
                          <td colspan="2"><input type="text" size="10" name="Total1A" value="0"/></td>
                          <td align="right"> </td>
                          <td> </td>
                          </tr>
                        <tr>
                          <td> </td>
                          <td height="27" align="right"> </td>
                          <td> </td>
                          <td> </td>
                          <td> </td>
                          </tr>
                        </table>
      </form>
                  </div>
                </div>
          </body>
          </html>
      __________________________________________________________________________________________ _____________
      <head>
      body,td,th {
      </style>
                          var sum = 0;
                          for (i=0;i<document.survey.radiogroup1A.length;i++) {
                            if (document.survey.radiogroup1A[i].checked) {
                                      sum = sum + parseInt(document.survey.radiogroup1A[i].value);
      </script>
      </head>
      <body>
          <br />
          <br />
          <br />
        </div>
        <div id="survey">
          <form name="survey" id="survey">
              <tr>
              </tr>
              <tr>
                <td width="60"><input type="radio" name="radiogroup1A" value="1" onchange="TotalPart1A()"/></td>
                <td width="60"><input type="radio" name="radiogroup1A" value="2" onchange="TotalPart1A()"/></td>
                <td width="60"><input type="radio" name="radiogroup1A" value="3" onchange="TotalPart1A()"/></td>
                <td width="60"><input type="radio" name="radiogroup1A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup2A" value="1" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup2A" value="2" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup2A" value="3" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup2A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td>3</td>
                <td><input type="radio" name="radiogroup3A" value="1" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup3A" value="2" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup3A" value="3" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup3A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup4A" value="1" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup4A" value="2" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup4A" value="3" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup4A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td>5</td>
                <td><input type="radio" name="radiogroup5A" value="1" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup5A" value="2" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup5A" value="3" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup5A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup6A" value="1" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup6A" value="2" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup6A" value="3" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup6A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td>7</td>
                <td><input type="radio" name="radiogroup7A" value="1" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup7A" value="2" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup7A" value="3" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup7A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup8A" value="1" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup8A" value="2" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup8A" value="3" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup8A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td>9</td>
                <td><input type="radio" name="radiogroup9A" value="1" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup9A" value="2" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup9A" value="3" onchange="TotalPart1A()"/></td>
                <td><input type="radio" name="radiogroup9A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup10A" value="1" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup10A" value="2" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup10A" value="3" onchange="TotalPart1A()"/></td>
                <td bgcolor="#EAEAEA"><input type="radio" name="radiogroup10A" value="4" onchange="TotalPart1A()"/></td>
              </tr>
              <tr>
                <td> </td>
                <td> </td>
              </tr>
              <tr>
                <td> </td>
                <td> </td>
                <td> </td>
                <td> </td>
              </tr>
            </table>
          </form>
        </div>
      </div>
      </body>
      </html>
