• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is there a way to limit this unwanted proliferation of Conditional Build Tags (CBT)?
Enthusiast ,
Feb 28, 2013 Feb 28, 2013
I have this simple topic with the following sentences marked as online only and a slight tweak to the original marked as print only:
In my mind, this would be a total of four CBTs:
An opening and closing tag that bound the online only (green) text.
An opening and closing tag that bound the print only (red) text.
Instead, any formatting or other change within each statement results in what seems like the addition of more unnecessary tags.
The items marked in yellow and red are what we think are not needed:
Our translators have to reposition all these tags after localizing the text--in all the supported languages, and this seeming unnecessary proliferation of CBTs is creating headaches for them.
Even if I manually delete the unecessary ones in the HTML pane, when I go to the WYSIWYG mode and back to HMTL they're all back again.
I doubt it, but I'm wondering if there a way to control this or is this just a bad RH design? Or possibly, is this actually necessary for a reason that I don't understand?
Views
400
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Mar 01, 2013 Mar 01, 2013
LATEST
It will depend on how you selected the text for applying the tags.
I suggest you right click and will likely see an option to Remove Attributes. Remove the tags that way.
Then start over. Without checking I agree it should be as you expect.
BTW. Did you post this question from within the OLH or direct to the forum in the normal way?
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
