Double Page feature is missing in the ADE 2.0. I have tried to find it, I have used the short keys, and I know that there was such an option in previous versions. I have read other comments here about the same thing. But no answer from the Adobe Support. I did chat tonight with a representative from Adobe, but he couldn' help me. In the list of products with support there are just ADE 1 and 1.7. How is it possible with a product without support? I would like to get an answer from Adobe and to know if you are working on the problem.
Just checked on 1.7.2 and that goes to 2 page view automatically once the window is wide enough. I can't find any explicity option to setting/unsetting it.
It may be that if you reduce all the 'furniture' around the page view as much as possible you will get 2.0 to give you double page ...???
There are lots of bugs in 2.0; it wasn't just the support they skimped on, but design, development and test as well.
I reverted to 1.7.2 because of bugs in 2.0 for Sony eReader, but lots of others have found
...Copy link to clipboard
I reverted to 1.7.2 because of bugs in 2.0 for Sony eReader, but lots of others have found it solved their issues.
Aha - now I found it! Thanks a lot. It was just to do as you suggested. I just pulled the window as much to the left as possible, and then it turned to a double page view. Great!
It doesn't seem to work with PDF books. I can't get two pages side by side. Is this a bug that still needs to be fixed or am I missing something? I'd appreciate any suggestions.
On 1.7.2 there is a 'menu~Reading~Fit double pages' for pdfs.
The first page appears alone, to keep the convention of even/odd page pairs.
Not sure on 2.0.
A good suggestion but it must be only on 1.7.2. Can't find that option in 2.0. I wish I hadn't upgraded before checking out the deltas in features.
To my mind you didn't upgrade to v2.0, you downgraded.
At least it is very easy to uninstall v2.0 and reinstall 1.7.2.
I understand it is perfectly easy to run both in parallel as well.
