11 Replies Latest reply on Sep 6, 2017 2:29 PM by lg84
    CF won't start with JDK 1.7
    tSpark
      Now that CF is certifified for JDK 1.7, I installed the latest update from Adobe and installed JDK 1.7.  However, ColdFusion 9.01 with Hotfix 3 on Windows 2008 will not start.
      This is the error in couldfusion-out.log
      Error loading: C:\Program Files\Java\jdk1.7.0\jre\bin\server\jvm.dll
      I confirmed that the jvm.dll file is there.  When I change the jvm.config file to point back to the original Java path, it starts fine.
      Anyone else run into this?
        • 1. Re: CF won't start with JDK 1.7
          carl type3 Level 4
          Copy msvcr100.dll out of JDK 7 and put it in CF9\runtime\bin.
          HTH, Carl.
          • 2. Re: CF won't start with JDK 1.7
            BKBK Adobe Community Professional & MVP
            Is that really the location of the jvm.dll file? My setting in jvm.config differs from your. It is:  java.home=C:\\Program Files\\java\jdk1.7.0_15\\jre
            • 3. Re: CF won't start with JDK 1.7
              tSpark Level 1
              Thanks Carl.  Your solution worked.  Very odd that Adobe would not include this in the documentation.
              Of course, even after your fix I ended up having to undo everything because 9.0.1 Hotfix 3 is full of bugs, including this showstopper for us.
              https://bugbase.adobe.com/index.cfm?event=bug&id=3488663
              So disappointed in Adobe's management of ColdFusion lately...
              • 4. Re: CF won't start with JDK 1.7
                You seem to be comparing 2 different things. The bug report you mentioned was filed for a ColdFusion system with update level hf901-00008.jar. If you installed Hotfix 3 according to the instructions, your own update would have been  chf9010003.jar instead!
                Did you notice the 15 in jdk1.7.0_15 in my previous post? Again, the installation instructions for Hotfix 3 do specifically mention that as the reference Java version.
                • 5. Re: CF won't start with JDK 1.7
                  tSpark Level 1
                  Yes, I saw your previous post.  My installation folder does not have the _15 on it.  My path is correct for my installation, and it works with Carl's solution.  That issue is resolved.  I was simply stating that I ended up having to roll it back because of a bug.
                  The bug I mentioned is a separate issue and still exists in Hotfix 3.  It was originally posted by a user with hf901-00008.jar, but that patch has been rolled into CHF3 and is still a major bug.
                  • 6. Re: CF won't start with JDK 1.7
                    I see. I will agree with you on one point. This is a bit of a mess.
                    The solution Carl gave you occurs as a suggestion in the installation instructions for Hotfix 3. It is itself a bad penny. Why would ColdFusion use the server JDK, yet require you to manually provide its runtime with a file from that same JDK? That is clearly a bug. In my opinion, the ColdFusion team needs to rethink and redo Hotfix 3.
                    • 7. Re: CF won't start with JDK 1.7
                      HiTopp
                      This appears to be a coldfusion single-server solution.  I am having a nearly identical issue with a multi-server installation.  Do you know of a related fix for that?
                      • 8. Re: CF won't start with JDK 1.7
                        carl type3 Level 4
                        Place copy of msvcr100.dll from JDK\bin in JRun4\bin edit jvm.config syntax so java.home=JDK\\jre.
                        If you have modified CF Enterprise multi instance to run separate JVM's then likely you will have to do something different.
                        HTH, Carl.
                        • 9. Re: CF won't start with JDK 1.7
                          Pawel Czarnota Level 1
                          Thank you carl type 3. After I copied the msvcr100.dll file to JRun4\bin in multiinstance I was able to lunch the instance I wanted to switch to Java 7. BTW, I'm on Cumulative Hotfix 4 (with Hotfix 10 installed on top of that) and still needed to copy that file.
                          • 10. Re: CF won't start with JDK 1.7
                            bryans31456166
                            For Coldfusion 10 running on Windows 2012, I ran into the same issue when I installed Hotfix_015.jar - Coldfusion failed to start with C:\Coldfusion\jre\bin\server\jvm.dll missing.
                            To solve the issue
                            1. I used a backup to restore Coldfusion 10 before the failed update (i.e. jvm missing) - you can skip this step if your Coldfusion is not broken.
                            2. I installed the Java JDK 8 update 11 x64.
                            3. Confirm that JDK was installed and that is the version of JAVA by default: Goto command prompt
                                 C:\java -version
                                 java version "1.8.0_11"
                                 Java(TM) SE RunTime Environment ....(truncated output)
                            3. Ran the updater again: C:\Coldfusion10\hf-updates\java -jar hotfix_015.jar
                            Coldfusion started normally after the update.
                            • 11. Re: CF won't start with JDK 1.7
                              lg84
                              For anyone else like me that might be reading this old but helpful post, I had the same error message trying to install java 7 on a coworker's 64 bit machine.  My issue was because she had the 32 bit version of CF installed.  (I finally figured this out by looking at the Java VM Name in CF administrator Settings Summary - it didn't have 64 bit in the name).  I installed the 32 bit jdk instead and all is well now.
