3 Replies Latest reply on Mar 2, 2013 12:07 PM by JJMack
    Keyboard shortcut from type tool to move tool
    Woody02905
      What is the keyboard shortcut again from the type tool to the move tool?
        • 1. Re: Keyboard shortcut from type tool to move tool
          conroy Level 5
          On a Mac, hold down Cmd to temporarily activate Move, allowing the Type to be dragged.
          • 2. Re: Keyboard shortcut from type tool to move tool
            Noel Carboni Level 8
            You want to move the text while you're typing it?  Hold down the Control key (on PC) then drag it with the mouse.
            -Noel
            • 3. Re: Keyboard shortcut from type tool to move tool
              If you hold the mouse over the tool in the tool palette Photoshop will pop up the answer for you.
              If you use menu Edit>Keyboard Shortcuts the use the summirize button Photoshop will save your shortcuts for in a HTML page. You can search that page
              Holding down the space key activate the hand tool
              Adobe®  Photoshop® CS6 Keyboard Shortcuts
              Application Menus
              Command
              Shortcut
              File
              New...Ctrl+N
              Open...Ctrl+O
              Browse in Bridge...Alt+Ctrl+O
              Shift+Ctrl+O
              Browse in Mini Bridge...
              Open As...Alt+Shift+Ctrl+O
              Open as Smart Object...
              Open Recent>
              Clear Recent File List
              CloseCtrl+W
              Close AllAlt+Ctrl+W
              Close and Go to Bridge...Shift+Ctrl+W
              SaveCtrl+S
              Save As...Shift+Ctrl+S
              Alt+Ctrl+S
              Check In...
              Save for Web...Alt+Shift+Ctrl+S
              RevertF12
              Place...
              Import>
              Variable Data Sets...
              Video Frames to Layers...
              Notes...
              WIA Support...
              Export>
              Data Sets as Files...
              Paths to Illustrator...
              Render Video...
              Zoomify...
              Automate>
              Batch...
              PDF Presentation...
              Create Droplet...
              Crop and Straighten Photos
              Contact Sheet II...
              Picture Package...
              Web Photo Gallery...
              Contact Sheet II...
              Absolute Aspect Ratio Selection...
              Fit Image...
              Long Side Print Length...
              Golden Crop
              Change Layer Content
              Conditional Mode Change...
              Fit Image...
              Lens Correction...
              Merge to HDR Pro...
              Photomerge...
              Scripts>
              Image Processor...
              Save For Web Batch
              Delete All Empty Layers
              Scripted Fill UI v 1.2
              Flatten All Layer Effects
              Flatten All Masks
              ActionTime
              orient
              SaveAndRestoreColors
              SaveAndRestoreResolution
              ConvertBackground
              DeleteDisplacementMap
              ExifData
              OneInchMiteredLeftEdgeSelection
              RandomColors
              RotatePortrait
              SelectBackground
              SelectEllipse
              SelectVignette
              SelectVignetteBorder
              Sleep2Seconds
              StampDate
              StampExif
              TimeStamp
              BatchMultiImageCollage
              BatchOneImageCollage
              BatchPicturePackage
              ChangeTextSize
              CollageTemplateBuilder
              HelpPhotoCollageToolkit
              InteractivePopulateCollage
              LayerToAlphaChan
              PasteImageRoll
              PopulateCollageTemplate
              PopulatePicturePackage
              ReplaceCollageImage
              TestCollageTemplate
              EditSessionTime
              SessionCurrentTime
              SessionEndTime
              SessionStartTime
              CanvasAR4x3
              ClipboardTo4SidePath
              NewBackground
              NewDocFromSelection
              OpenImageFromWeb
              StackWebPageImages
              MouseprintsSimpleViewer
              MouseprintsWs-Slideshow
              MouseprintsXMLSlideshow
              OMousprintsSimpleViewer
              Layer Comps to Files...
              Layer Comps to PDF...
              Layer Comps to WPG...
              Export Layers to Files...
              Script Events Manager...
              Add Texture
              addmat
              AnimateLayers
              CanvasAR
              ChangeCaption
              CollageBuilder
              ConnectDots
              DeleteEmptyLayers
              DeleteHiddenLayers
              DeleteSelectedArea
              dialogCracks
              Distribute Layers
              DoAction
              Dr. Brown's Edit Layer in ACR
              DupeDocToPSD
              EllipticallCrop
              emailer
              fontlist
              ForceAspectRatio
              ForceAspectRatio4to3
              ForceFit
              GetFilesFromBridge
              GridMaker
              Image Processor Pro
              Jeffrey's Calendar Builder
              Layer Saver
              LayersChannelsAndPaths
              LensInfo
              Load Files into Stack...
              LoadFilesIntoStrip
              LoadFilesIntoStripBottomUp
              metadata
              Name_1024
              NewFittedLayer
              pdfslideshow
              philg-pscs2-processor
              Picture ProcessorII
              PShotFolder
              Resize1600wide0r1200high
              Resize6x4
              ResizeWidthFor4x3Crop
              ResizeWidthFor8byCrop
              ResizeWidthFor8x3Crop
              ReszeInSteps
              RunAction
              Shaun's Open Map From GPS Location
              Show Font Name
              Siva's Photoshop Conditional Action
              spiderWeb
              StitchImages
              TransformLayersToFit
              TransformLayerToCanvasSize
              vScriptListener
              Browse...
              File Info...Alt+Shift+Ctrl+I
              Print...Ctrl+P
              Print One CopyAlt+Shift+Ctrl+P
              ExitCtrl+Q
              Edit
              Undo/RedoCtrl+Z
              Step ForwardShift+Ctrl+Z
              Step BackwardAlt+Ctrl+Z
              Fade...Shift+Ctrl+F
              CutCtrl+X
              F2
              CopyCtrl+C
              F3
              Copy MergedShift+Ctrl+C
              PasteCtrl+V
              F4
              Paste Special>
              Paste in PlaceShift+Ctrl+V
              Paste IntoAlt+Shift+Ctrl+V
              Paste Outside
              Clear
              Check Spelling...
              Find and Replace Text...
              Fill...Shift+F5
              Stroke...
              Content-Aware ScaleAlt+Shift+Ctrl+C
              Puppet Warp
              Free TransformCtrl+T
              Transform>
              AgainShift+Ctrl+T
              Scale
              Rotate
              Skew
              Distort
              Perspective
              Warp
              Rotate 180°
              Rotate 90°  CW
              Rotate 90°  CCW
              Flip Horizontal
              Flip Vertical
              Auto-Align Layers...
              Auto-Blend Layers...
              Define Brush Preset...
              Define Pattern...
              Define Custom Shape...
              Purge>
              Undo
              Clipboard
              Histories
              All
              Video Cache
              Adobe PDF Presets...
              Presets>
              Preset Manager...
              Migrate Presets
              Export/Import Presets...
              Remote Connections...
              Color Settings...Shift+Ctrl+K
              Assign Profile...
              Convert to Profile...
              Keyboard Shortcuts...Alt+Shift+Ctrl+K
              Menus...Alt+Shift+Ctrl+M
              Preferences>
              General...Ctrl+K
              Interface...
              File Handling...
              Performance...
              Cursors...
              Transparency & Gamut...
              Units & Rulers...
              Guides, Grid & Slices...
              Plug-Ins...
              Type...
              Camera Raw...
              Mode>
              Bitmap
              Grayscale
              Duotone
              Indexed Color
              RGB Color
              CMYK Color
              Lab Color
              Multichannel
              8 Bits/Channel
              16 Bits/Channel
              32 Bits/Channel
              Color Table...
              Adjustments>
              Brightness/Contrast...
              Levels...Ctrl+L
              Curves...Ctrl+M
              Exposure...
              Vibrance...
              Hue/Saturation...Ctrl+U
              Color Balance...Ctrl+B
              Black & White...Alt+Shift+Ctrl+B
              Photo Filter...
              Channel Mixer...
              Color Lookup...
              InvertCtrl+I
              Posterize...
              Threshold...
              Gradient Map...
              Selective Color...
              Shadows/Highlights...
              HDR Toning...
              Variations...
              DesaturateShift+Ctrl+U
              Match Color...
              Replace Color...
              Equalize
              Auto ToneShift+Ctrl+L
              Auto ContrastAlt+Shift+Ctrl+L
              Auto ColorShift+Ctrl+B
              Image Size...Alt+Ctrl+I
              Canvas Size...Alt+Ctrl+C
              Image Rotation>
              180°
              90°  CW
              90°  CCW
              Arbitrary...
              Flip Canvas Horizontal
              Flip Canvas Vertical
              Crop
              Trim...
              Reveal All
              Duplicate...
              Apply Image...
              Calculations...
              Variables>
              Define...
              Data Sets...
              Apply Data Set...
              Trap...
              Analysis>
              Set Measurement Scale>
              Select Data Points>
              Record Measurements
              Ruler Tool
              Count Tool
              Place Scale Marker...
              Layer
              New>
              Layer...Shift+Ctrl+N
              Background
              Group...
              Group from Layers...
              Layer Via CopyCtrl+J
              Layer Via CutShift+Ctrl+J
              Duplicate Layer (Group)...
              Delete>
              Delete Layer (Group)
              Hidden Layers
              Rename Layer...
              Layer Style>
              Blending Options...
              Bevel & Emboss...
              Stroke...
              Inner Shadow...
              Inner Glow...
              Satin...
              Color Overlay...
              Gradient Overlay...
              Pattern Overlay...
              Outer Glow...
              Drop Shadow...
              Copy Layer Style
              Paste Layer Style
              Clear Layer Style
              Global Light...
              Create Layer
              Show/Hide All Effects
              Scale Effects...
              Smart Filter>
              Disable Smart Filters
              Delete Filter Mask
              Disable Filter Mask
              Clear Smart Filters
              New Fill Layer>
              Solid Color...
              Gradient...
              Pattern...
              New Adjustment Layer>
              Levels...
              Curves...
              Exposure...
              Vibrance...
              Hue/Saturation...
              Color Balance...
              Black & White...
              Photo Filter...
              Channel Mixer...
              Color Lookup...
              Invert...
              Posterize...
              Threshold...
              Gradient Map...
              Selective Color...
              Layer Content Options...
              Layer Mask>
              Reveal All
              Hide All
              Reveal Selection
              Hide Selection
              From Transparency
              Delete
              Apply
              Enable/Disable Layer Mask
              Link/Unlink Layer Mask
              Vector Mask>
              Reveal All
              Hide All
              Current Path
              Delete
              Enable/Disable Vector Mask
              Link/Unlink Vector Mask
              Create/Release Clipping MaskAlt+Ctrl+G
              Smart Objects>
              Convert to Smart Object
              New Smart Object via Copy
              Edit Contents
              Export Contents...
              Replace Contents...
              Stack Mode>
              None
              Rasterize
              Video Layers>
              New Video Layer from File...
              New Blank Video Layer
              Insert Blank Frame
              Duplicate Frame
              Delete Frame
              Replace Footage...
              Interpret Footage...
              Show Altered Video
              Restore Frame
              Restore All Frames
              Reload Frame
              Rasterize
              Rasterize>
              Type
              Shape
              Fill Content
              Vector Mask
              Smart Object
              Video
              Layer Style
              Layer
              All Layers
              New Layer Based Slice
              Group LayersCtrl+G
              Ungroup LayersShift+Ctrl+G
              Hide Layers
              Arrange>
              Bring to FrontShift+Ctrl+]
              Bring ForwardCtrl+]
              Send BackwardCtrl+[
              Send to BackShift+Ctrl+[
              Reverse
              Combine Shapes>
              Unite Shapes
              Subtract Front Shape
              Unite Shapes at Overlap
              Subtract Shapes at Overlap
              Align>
              Top Edges
              Vertical Centers
              Bottom Edges
              Left Edges
              Horizontal Centers
              Right Edges
              Distribute>
              Top Edges
              Vertical Centers
              Bottom Edges
              Left Edges
              Horizontal Centers
              Right Edges
              Lock Layers...
              Link/Unlink Layers
              Select Linked Layers
              Merge LayersCtrl+E
              Merge VisibleShift+Ctrl+E
              Flatten Image
              Matting>
              Color Decontaminate...
              Defringe...
              Remove Black Matte
              Remove White Matte
              Type
              Panels>
              Character Panel
              Paragraph Panel
              Character Styles Panel
              Paragraph Styles Panel
              Anti-Alias>
              None
              Sharp
              Crisp
              Strong
              Smooth
              Orientation>
              Horizontal
              Vertical
              OpenType>
              Standard Ligatures
              Contextual Alternates
              Discretionary Ligatures
              Swash
              Oldstyle
              Stylistic Alternates
              Titling Alternates
              Ornaments
              Ordinals
              Fractions
              Justification Alternates
              Japanese 78
              Japanese Expert
              Japanese Traditional
              Proportional Metrics
              Kana
              Roman Italics
              Create Work Path
              Convert to Shape
              Rasterize Type Layer
              Convert Text Shape Type
              Warp Text...
              Font Preview Size>
              None
              Small
              Medium
              Large
              Extra Large
              Huge
              Language Options>
              Default Features
              East Asian Features
              Standard Vertical Roman Alignment
              Tate-chu-yoko
              Top-to-Top Leading
              Bottom-to-Bottom Leading
              Update All Text Layers
              Replace All Missing Fonts
              Paste Lorem Ipsum
              Select
              AllCtrl+A
              DeselectCtrl+D
              ReselectShift+Ctrl+D
              InverseShift+Ctrl+I
              Shift+F7
              All LayersAlt+Ctrl+A
              Deselect Layers
              Find LayersAlt+Shift+Ctrl+F
              Color Range...
              Refine Mask...Alt+Ctrl+R
              Modify>
              Border...
              Smooth...
              Expand...
              Contract...
              Feather...Shift+F6
              Grow
              Similar
              Transform Selection
              Edit in Quick Mask Mode
              Load Selection...
              Save Selection...
              Filter
              Last FilterCtrl+F
              Convert for Smart Filters
              Filter Gallery...
              Adaptive Wide Angle...Shift+Ctrl+A
              Lens Correction...Shift+Ctrl+R
              Liquify...Shift+Ctrl+X
              Oil Paint...
              Vanishing Point...Alt+Ctrl+V
              Blur>
              Field Blur...
              Iris Blur...
              Tilt-Shift...
              Average
              Blur
              Blur More
              Box Blur...
              Gaussian Blur...
              Lens Blur...
              Motion Blur...
              Radial Blur...
              Shape Blur...
              Smart Blur...
              Surface Blur...
              Distort>
              Displace...
              Pinch...
              Polar Coordinates...
              Ripple...
              Shear...
              Spherize...
              Twirl...
              Wave...
              ZigZag...
              Noise>
              Add Noise...
              Despeckle
              Dust & Scratches...
              Median...
              Reduce Noise...
              Pixelate>
              Color Halftone...
              Crystallize...
              Facet
              Fragment
              Mezzotint...
              Mosaic...
              Pointillize...
              Render>
              Clouds
              Difference Clouds
              Fibers...
              Lens Flare...
              Lighting Effects...
              Sharpen>
              Sharpen
              Sharpen Edges
              Sharpen More
              Smart Sharpen...
              Unsharp Mask...
              Stylize>
              Diffuse...
              Emboss...
              Extrude...
              Find Edges
              Solarize
              Tiles...
              Trace Contour...
              Wind...
              Video>
              De-Interlace...
              NTSC Colors
              Other>
              Custom...
              High Pass...
              Maximum...
              Minimum...
              Offset...
              Digimarc>
              Embed Watermark...
              Read Watermark...
              Neat Image>
              Reduce Noise...
              Browse Filters Online...
              Faster Color Match v1
              Locate File
              View
              Proof Setup>
              Custom...
              Working CMYK
              Working Cyan Plate
              Working Magenta Plate
              Working Yellow Plate
              Working Black Plate
              Working CMY Plates
              Legacy Macintosh RGB (Gamma 1.8)
              Internet Standard RGB (sRGB)
              Monitor RGB
              Color Blindness - Protanopia-type
              Color Blindness - Deuteranopia-type
              Proof ColorsCtrl+Y
              Gamut WarningShift+Ctrl+Y
              Pixel Aspect Ratio>
              Custom Pixel Aspect Ratio...
              Delete Pixel Aspect Ratio...
              Reset Pixel Aspect Ratios...
              Square
              D1/DV NTSC (0.91)
              D1/DV PAL (1.09)
              D1/DV NTSC Widescreen (1.21)
              HDV 1080/DVCPRO HD 720 (1.33)
              D1/DV PAL Widescreen (1.46)
              Anamorphic 2:1 (2)
              DVCPRO HD 1080 (1.5)
              Pixel Aspect Ratio Correction
              32-bit Preview Options...
              Zoom InCtrl++
              Ctrl+=
              Zoom OutCtrl+-
              Fit on ScreenCtrl+0
              Actual PixelsCtrl+1
              Alt+Ctrl+0
              Print Size
              Screen Mode>
              Standard Screen Mode
              Full Screen Mode With Menu Bar
              Full Screen Mode
              ExtrasCtrl+H
              Show>
              Layer Edges
              Selection Edges
              Target PathShift+Ctrl+H
              GridCtrl+'
              GuidesCtrl+;
              Smart Guides
              Slices
              Notes
              Pixel Grid
              Brush Preview
              Mesh
              Edit Pins
              All
              None
              Show Extras Options...
              RulersCtrl+R
              SnapShift+Ctrl+;
              Snap To>
              Guides
              Grid
              Layers
              Slices
              Document Bounds
              All
              None
              Lock GuidesAlt+Ctrl+;
              Clear Guides
              New Guide...
              Lock Slices
              Clear Slices
              Window
              Arrange>
              Tile All Vertically
              Tile All Horizontally
              2-up Horizontal
              2-up Vertical
              3-up Horizontal
              3-up Vertical
              3-up Stacked
              4-up
              6-up
              Consolidate All to Tabs
              Cascade
              Tile
              Float in Window
              Float All in Windows
              Match Zoom
              Match Location
              Match Rotation
              Match All
              New Window
              Workspace>
              DualScreen
              Essentials (Default)
              New in CS 6
              Motion
              Painting
              Photography
              Typography
              Reset DualScreen
              New Workspace...
              Delete Workspace...
              Keyboard Shortcuts & Menus...
              Extensions>
              ActionsAlt+F9
              F9
              Adjustments
              BrushF5
              Brush Presets
              Channels
              Character
              Character Styles
              Clone Source
              ColorF6
              Histogram
              History
              InfoF8
              Layer Comps
              LayersF7
              Navigator
              Notes
              Paragraph
              Paragraph Styles
              Paths
              Properties
              Styles
              Swatches
              Timeline
              Tool Presets
              Options
              Tools
              Help
              Photoshop HelpF1
              Photoshop Support Center...
              About Photoshop...
              Legal Notices...
              System Info...
              Complete/Update Adobe ID Profile...
              Deactivate...
              Updates...
              Photoshop Online...
              Photoshop Resources Online...
              Adobe Product Improvement Program...
              Panel Menus
              Command
              Shortcut
              3D
              Snap Object to Ground Plane
              Select Paintable Areas
              Create Painting Overlay>
              Wireframe
              Shaded
              Normals
              Add Lights Preset...
              Replace Lights Presets...
              Save Lights Preset...
              Delete Current Lights Preset
              RenderAlt+Shift+Ctrl+R
              Export 3D Layer...
              Close
              Close Tab Group
              Actions
              Button Mode
              New Action...
              New Set...
              Duplicate
              Delete
              Play
              Start/Stop Recording
              Record Again...
              Insert Menu Item...
              Insert Stop...
              Insert Path
              Action Options...
              Playback Options...
              Allow Tool Recording
              Clear All Actions
              Reset Actions
              Load Actions...
              Replace Actions...
              Save Actions...
              Commands
              Frames
              Image Effects
              LAB - Black & White Technique
              Production
              Stars Trails
              Text Effects
              Textures
              Video Actions
              Close
              Close Tab Group
              Adjustments
              Auto-Select Parameter
              Reset
              Save Preset...
              Load Preset...
              Delete Current Preset
              Auto Options (Levels/Curves)...
              Show Clipping for Black/White Points (Levels/Curves)
              Curves Display Options...
              Brightness/Contrast
              Levels
              Curves
              Exposure
              Vibrance
              Hue/Saturation
              Color Balance
              Black & White
              Photo Filter
              Channel Mixer
              Invert
              Posterize
              Threshold
              Gradient Map
              Selective Color
              Color Lookup
              Add Mask by Default
              Clip to Layer
              Close
              Close Tab Group
              Brush Presets
              New Brush Preset...
              Rename Brush...
              Delete Brush
              Text Only
              Small Thumbnail
              Large Thumbnail
              Small List
              Large List
              Stroke Thumbnail
              Preset Manager...
              Reset Brushes...
              Load Brushes...
              Save Brushes...
              Replace Brushes...
              Assorted Brushes
              Basic Brushes
              Calligraphic Brushes
              DP Brushes
              Drop Shadow Brushes
              Dry Media Brushes
              Faux Finish Brushes
              M Brushes
              Natural Brushes 2
              Natural Brushes
              Round Brushes with Size
              Special Effect Brushes
              Square Brushes
              Thick Heavy Brushes
              Wet Media Brushes
              Close
              Close Tab Group
              Brushes
              New Brush Preset...
              Clear Brush Controls
              Reset All Locked Settings
              Copy Texture to Other Tools
              Channels
              New Channel...
              Duplicate Channel...
              Delete Channels
              New Spot Channel...
              Merge Spot Channel
              Channel Options
              Split Channels
              Merge Channels...
              Panel Options...
              Close
              Close Tab Group
              Clone Source
              Source 1
              Source 2
              Source 3
              Source 4
              Source 5
              Reset Transform
              Lock Frame
              Show Overlay
              Clip to Brush Tip
              Auto Hide Overlay
              Invert Overlay
              Close
              Close Tab Group
              Color
              Grayscale Slider
              RGB Sliders
              HSB Sliders
              CMYK Sliders
              Lab Sliders
              Web Color Sliders
              Copy Color as HTML
              Copy Color's Hex Code
              RGB Spectrum
              CMYK Spectrum
              Grayscale Ramp
              Current Colors
              Make Ramp Web Safe
              Close
              Close Tab Group
              Histogram
              Uncached Refresh
              Compact View
              Expanded View
              All Channels View
              Show Statistics
              Show Channels in Color
              Close
              Close Tab Group
              History
              New Snapshot...
              Delete
              Clear History
              New Document
              History Options...
              Close
              Close Tab Group
              Info
              Panel Options...
              Color Samplers
              Close
              Close Tab Group
              Layer Comps
              New Layer Comp...
              Duplicate Layer Comp
              Delete Layer Comp
              Update Layer Comp
              Apply Layer Comp
              Next Layer Comp
              Previous Layer Comp
              Restore Last Document State
              Layer Comp Options...
              Close
              Close Tab Group
              Layers
              New Layer...Shift+Ctrl+N
              Delete Hidden Layers
              New Group...
              New Group from Layers...
              Lock Layers...
              Edit Contents
              Blending Options...
              Edit Adjustment...
              Link/Unlink Layers
              Merge LayersCtrl+E
              Flatten Image
              Animation Options>
              Automatic
              Always Show
              Always Hide
              Panel Options...
              Close
              Close Tab Group
              Navigator
              Panel Options...
              Close
              Close Tab Group
              Paths
              New Path...
              Duplicate Path...
              Delete Path
              Make Work Path...
              Make Selection...
              Fill Path...
              Stroke Path...
              Clipping Path...
              Panel Options...
              Close
              Close Tab Group
              Properties
              Close
              Close Tab Group
              Status
              Versions...
              Show in Bridge...
              Show>
              Adobe Drive
              Document Sizes
              Document Profile
              Document Dimensions
              Scratch Sizes
              Efficiency
              Timing
              Current Tool
              32-bit Exposure
              Save Progress
              Styles
              New Style...
              Text Only
              Small Thumbnail
              Large Thumbnail
              Small List
              Large List
              Preset Manager...
              Reset Styles...
              Load Styles...
              Save Styles...
              Replace Styles...
              Abstract Styles
              Buttons
              Dotted Strokes
              DP Styles
              Glass Buttons
              Image Effects
              KS Styles
              Photographic Effects
              Text Effects 2
              Text Effects
              Textures
              Web Styles
              Close
              Close Tab Group
              Swatches
              New Swatch...
              Small Thumbnail
              Large Thumbnail
              Small List
              Large List
              Preset Manager...
              Reset Swatches...
              Load Swatches...
              Save Swatches...
              Save Swatches for Exchange...
              Replace Swatches...
              ANPA Colors
              DIC Color Guide
              FOCOLTONE Colors
              HKS E Process
              HKS E
              HKS K Process
              HKS K
              HKS N Process
              HKS N
              HKS Z Process
              HKS Z
              Mac OS
              Paint Color Swatches
              PANTONE solid coated
              PANTONE solid uncoated
              PANTONE+ CMYK Coated
              PANTONE+ CMYK Uncoated
              PANTONE+ Color Bridge Coated
              PANTONE+ Color Bridge Uncoated
              PANTONE+ Metallic Coated
              PANTONE+ Pastels & Neons Coated
              PANTONE+ Pastels & Neons Uncoated
              PANTONE+ Premium Metallics Coated
              PANTONE+ Solid Coated
              PANTONE+ Solid Uncoated
              Photo Filter Colors
              TOYO 94 COLOR FINDER
              TOYO COLOR FINDER
              TRUMATCH Colors
              VisiBone
              VisiBone2
              Web Hues
              Web Safe Colors
              Web Spectrum
              Windows
              Close
              Close Tab Group
              Timeline (Frames)
              New Frame
              Delete Frames
              Delete Animation
              Copy Frames
              Paste Frames...
              Select All Frames
              Go To>
              Next Frame
              Previous Frame
              First Frame
              Last Frame
              Tween...
              Reverse Frames
              Optimize Animation...
              Make Frames From Layers
              Flatten Frames Into Layers
              Match Layer Across Frames...
              Create New Layer for Each New Frame
              New Layers Visible in All Frames
              Convert to Video Timeline
              Panel Options...
              Close
              Close Tab Group
              Timeline (Video)
              Go To>
              Time...
              Next Frame
              Previous Frame
              First Frame
              Last Frame
              Start of Work Area
              End of Work Area
              Split at Playhead
              Move & Trim>
              Move Start to Playhead
              Move End to Playhead
              Trim Start at Playhead
              Trim End at Playhead
              Convert Frames>
              Make Frames from Clips
              Flatten Frames into Clips
              Convert to Frame Animation
              Work Area>
              Set Start at Playhead
              Set End at Playhead
              Extract Work Area
              Lift Work Area
              Keyframes>
              Delete
              Copy
              Paste
              Select All
              Deselect All
              Linear Interpolation
              Hold Interpolation
              Comments>
              Edit Timeline Comment...
              Export As HTML...
              Export As Text...
              Loop Playback
              Allow Frame Skipping
              Show>
              All Clips
              Video Groups Only
              Favorite Clips Only
              Set Favorite Clips
              Comments Track
              Global Light Track
              Enable Timeline Shortcut Keys
              Enable Auto-Grouping of Clips
              Enable Onion Skins
              Onion Skin Settings...
              Set Timeline Frame Rate...
              Panel Options...
              Render Video...
              Close
              Close Tab Group
              Tool Presets
              New Tool Preset...
              Rename Tool Preset...
              Delete Tool Preset
              Sort by Tool
              Show All Tool Presets
              Show Current Tool Presets
              Text Only
              Small List
              Large List
              Reset Tool
              Reset All Tools
              Preset Manager...
              Reset Tool Presets...
              Load Tool Presets...
              Save Tool Presets...
              Replace Tool Presets...
              Airbrushes
              Art History
              Artists' Brushes
              Brushes
              Crop and Marquee
              DP Presets
              Dry Media
              Pencil Brushes
              Pencils Mixer Brush
              Splatter Brush Tool Presets
              Text
              Close
              Close Tab Group
              Tools
              Tools
              Shortcut
              Move Tool
              V
              Rectangular Marquee Tool
              M
              Elliptical Marquee Tool
              M
              Single Row Marquee Tool
              Single Column Marquee Tool
              Lasso Tool
              L
              Polygonal Lasso Tool
              L
              Magnetic Lasso Tool
              L
              Quick Selection Tool
              W
              Magic Wand Tool
              W
              Eyedropper Tool
              I
              Color Sampler Tool
              I
              Ruler Tool
              I
              Note Tool
              I
              Crop Tool
              C
              Perspective Crop Tool
              C
              Slice Tool
              C
              Slice Select Tool
              C
              Spot Healing Brush Tool
              J
              Healing Brush Tool
              J
              Patch Tool
              J
              Content-Aware Move Tool
              J
              Red Eye Tool
              J
              Brush Tool
              B
              Pencil Tool
              B
              Color Replacement Tool
              B
              Mixer Brush Tool
              B
              Clone Stamp Tool
              S
              Pattern Stamp Tool
              S
              History Brush Tool
              Y
              Art History Brush Tool
              Y
              Eraser Tool
              E
              Background Eraser Tool
              E
              Magic Eraser Tool
              E
              Gradient Tool
              G
              Paint Bucket Tool
              G
              Blur Tool
              Sharpen Tool
              Smudge Tool
              Dodge Tool
              O
              Burn Tool
              O
              Sponge Tool
              O
              Pen Tool
              P
              Freeform Pen Tool
              P
              Add Anchor Point Tool
              Delete Anchor Point Tool
              Convert Point Tool
              Horizontal Type Tool
              T
              Vertical Type Tool
              T
              Horizontal Type Mask Tool
              T
              Vertical Type Mask Tool
              T
              Path Selection Tool
              A
              Direct Selection Tool
              A
              Rectangle Tool
              U
              Rounded Rectangle Tool
              U
              Ellipse Tool
              U
              Polygon Tool
              U
              Line Tool
              U
              Custom Shape Tool
              U
              Hand Tool
              H
              Rotate View Tool
              R
              Zoom Tool
              Z
              Targeted Adjustment Tool
              Default Foreground/Background Colors
              D
              Switch Foreground/Background Colors
              X
              Toggle Standard/Quick Mask Modes
              Q
              Toggle Screen Modes
              F
              Toggle Preserve Transparency
              Decrease Brush Size
              Increase Brush Size
              Decrease Brush Hardness
              Increase Brush Hardness
              Previous Brush
              Next Brush
              First Brush
              Last Brush
              Foreground Color Picker
              Background Color Picker
              Load Mixer Brush
              Clean Mixer Brush
              Toggle Mixer Brush Auto-Load
              Toggle Mixer Brush Auto-Clean
              Toggle Mixer Brush Sample All Layers
              Sharpen Erodible Tips
