12 Replies Latest reply on Mar 8, 2013 3:10 PM by ianncl
    Drop Down Boxes
    ianncl Level 1
      I am developing a form that allows the user to select an option from a drop down list of four options. The second drop down list is to allow them to pick from the same options minus the one they chose in the first drop down list.
      Basically if the first option is not available what would your second option be? We don’t want them to choose the same option in both instances.
        • 1. Re: Drop Down Boxes
          Mandy_Wiesener Level 3
          1. You create the first dropdown, for example with the following entries:
          • 123
          • 456
          • 789
          2. You create a second dropdown which is empty.
          3. Then you have to copy the follwoing script in the change-event of the first dropdown:
          switch (xfa.event.newText)
              case "123":
                  DropdownListe2.clearItems();
                  DropdownListe2.addItem("Please select a value");
                  DropdownListe2.addItem("456");
                  DropdownListe2.addItem("789");
                  DropdownListe2.selectedIndex = 0;
                  break;
              case "456":
                  DropdownListe2.addItem("123");
                  break;
              case "789":
                  break;
              default:
                  break;
          That's all.
          I hope it's helpful for you,
          kind regards,
          Mandy
          • 2. Re: Drop Down Boxes
            ianncl Level 1
            Thanks Mandy,
            The script works well, except if the user changes their mind on their first option they can select the same second option as the first option.
            Any ideas,
            Ian
            • 3. Re: Drop Down Boxes
              Hi Ian,
              sorry my english isn't the best. Therefore I don't understand your question.
              • You said the user select a value in the first dropdown for example "123".
              • Then makes the script that he can select only "456" or "789" in the second dropdown.
              • Then he want to change his first choice in the first dropdown??
              No problem with this script.
              If the user after the first choice in the first dropdown he can change the first dropdown and the second dropdown is also changed.
              For eample:
              1.Choice
              1.DD -> 123
              2.DD -> 456 or 789
              2. Choice - then he select
              1. DD -> 456
              2. DD -> 123 or 789
              Could you create your scenario when I'm wrong.
              Regards Mandy
              • 4. Re: Drop Down Boxes
                ianncl Level 1
                Thanks Mandy
                Yes that's correct
                Ian Nicol
                Narara Valley High School
                Fountains  Rd
                Narara, 2250
                Phone - 43293780
                • 5. Re: Drop Down Boxes
                  Hi Ian,
                  "my" scenario works correct with the script. Where is the problem?
                  Kind regards Mandy
                  • 6. Re: Drop Down Boxes
                    ianncl Level 1
                    Sorry for my poor explanation, I'll try to explain now that you have the form.
                    If I select, for example choice 1 flying fox, then pick High ropes in choice 2, then go back to choice 1 I am able replace flying fox with high ropes which means I can still get the person choosing the same things for both choices, which I was trying to avoid.
                    Thanks again and sorry for being a pain.
                    Ian Nicol
                    Fountains  Rd
                    Narara, 2250
                    Phone - 43293780
                    • 7. Re: Drop Down Boxes
                      Hi Ian,
                      I come from germany and my english is very terrible. Sorry.
                      But I don't understand.
                      1. Choice 1 you select - flying fox
                      2. Choice 2 you select - High ropes
                      3. Then Choice 1 - you select - Hight ropes
                      4. And in this moment the Choice 2 would be reset automatically. It's not able that in Choice 1 and Choice 2 you have the same entry with this script! Never.
                      I can send you my pdf with my script. Perhaps you have a mistake in your pdf? Make you a accurate copy of "my" script or change you anything?
                      I try a little bit. When you delete the following script lines it's your scenario possible. Do you delete this?
                      Kind regards Mandy
                      • 8. Re: Drop Down Boxes
                        ianncl Level 1
                        Thanks Mandy that would be great
                        Ian Nicol
                        Fountains  Rd
                        Narara, 2250
                        Phone - 43293780
                        • 9. Re: Drop Down Boxes
                          I need your email.
                          • 10. Re: Drop Down Boxes
                            Martin Grimm Level 1
                            Hello Ian,
                            I might have a solution for you. It is based on the preOpen event and can be scaled to an arbitrary number of list elements and drop down lists.
                            You can download an example from my Acrobat.com workspace (click on the download button on the top left so save the file locally, as Acrobat.com won't display Designer/XFA documents in the browser).
                            The preOpen event is executed each time a user opens the list to make a selection and allows you to filter or add elements just before the list is shown. Because all subforms use the same code, I created a script object called "scoManageChoices".
                            PreOpen Event of each drop down list
                            scoManageChoices.restrictChoices(this);
                            Script Object "scoManageChoices"
                            // setup E4X XML variable containing viable choices
                            var choices = <choices>
                                <choice>Canyoning</choice>
                                <choice>Flying Fox</choice>
                                <choice>High Ropes</choice>
                                <choice>White Water Rafting</choice>
                            </choices>
                            function restrictChoices(dropdown) {
                                // collect choices contained in other dropdowns
                                var dropdowns = dropdown.all; // get all dropdowns with same name/hierarchy
                                var otherChoices = []; // initialize empty array to save other choices
                                for (var i = 0; i < dropdowns.length; i++) {
                                    var dd = dropdowns.item(i); // retrieve dropdown from list
                                    if (dd.isNull || dd == dropdown) continue; // skip empty or current dropdowns
                                    otherChoices.push(dd.rawValue); // save value of other non-empty dropdown into array
                                // fill current dropdown with choices
                                dropdown.clearItems(); // reset current dropdown
                                for each (var choice in choices.choice) { // loop through viable choices
                                    if (otherChoices.indexOf(choice.toString()) > -1) { // skip adding to dropdown list if other dropdown already selected the choice
                                        continue;
                                    dropdown.addItem(choice.toString()); // add to dropdown
                            To make things easier in the script I placed all drop down lists within the same subform and gave all of them the same name, so that I can find them with the "all" property of the field (see the code example above).
                            I specified the viable choices in a format called E4X that is supported by Acrobat/Reader's Javascript engine and documented here (don't be scared by the deprecation notice, it continues to work in Acrobat/Reader).
                            Hope that helps,
                            Martin
                            • 12. Re: Drop Down Boxes
                              ianncl Level 1
                              Thanks  so much for your help it works fine. I was changing  DropdownListe2.addItem(""); to not allow the user to submit the form unless they chose a value from the dropdown box as it is a mandatory field. I will just use the original script, Thanks again.
