0 Replies Latest reply on Mar 4, 2013 7:18 AM by Nemo1059
    Populate text boxes from drop down choices
    Nemo1059
      I have a form with two drop down boxes, the second of which populates three text fields.
      In the first, there are two choices (A &B). If you select A, it populates the second drop down with (C&D).
      If you select B, it populates the second drop down with (E&F).
      I cannot get the three text fields to populate from a function that I have set up.
      I can however, get the text boxes to populate with the contents of the second drop down (C, D, E, or F).
      I have been strugling with this for two weeks and need help.
      Thanks in advance:
      Here is a link to a copy of my code:
      http://dl.dropbox.com/u/104646823/test%20script.txt
