1. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
John T Smith Mar 4, 2013 7:56 PM (in response to VidNoob)Since this is a user to user forum, with only sporadic postings by Adobe staff, you should file a bug report
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
2. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
Jeff Bellune Mar 5, 2013 3:54 AM (in response to VidNoob)I have a 560 Ti running the 314.07 drivers and I use hardware MPE. I don't bother with GPUSniffer any more -- I just delete the cuda_supported_cards.txt file. Pr doesn't skip a beat and I get all of its CUDA goodness.
Jeff
3. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
digitlman Mar 5, 2013 4:48 AM (in response to VidNoob)why dont you paste your gpusniffer results and your cuda.txt file in here for us to see. 99% of the time it is a typo in the txt file.
4. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
JSS1138 Mar 5, 2013 8:00 AM (in response to VidNoob)I also use a 560 Ti, and all drivers have worked no problems. This isn't an nVidia or PP issue, something on your machine got wonky.
5. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
VidNoob Mar 5, 2013 5:59 PM (in response to JSS1138)OK guys, i just went ahead and made a video showing you exactly what I'm doing and what happens with new and old drivers installed. You'll see that the new drivers simply do not work with everything else necessary to make the hack work remaining constant. In the middle of the video you might want to skip through since there's a long spot where the old drivers are installed.
I'm totally open to the fact that something could still be wrong on my end, but what can it be when this video shows the only difference between it working and not is clearly a driver change??
6. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
JSS1138 Mar 5, 2013 6:07 PM (in response to VidNoob)something could still be wrong on my end, but what can it be
I'm stumped on this myself. I only know that it normally does work. I just don't have any ideas about why it isn't for you.
I don't know how this might tie in, but I've never used GPUsniffer, or changed any of the nVidia settings. Simply adding the card to the text file has always worked. Maybe you've changed something in the nVidia settings that makes a difference.
7. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
VidNoob Mar 5, 2013 6:13 PM (in response to JSS1138)The only thing I changed in the Nvidia side of things was selecting the premiere exe and setting the multi display acceleration to compatability mode as had been adivsed in many articles and videos explaining the hack. I have been tweaking those settings back and forth with the new drivers but they do nothing either.
9. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
JSS1138 Mar 15, 2013 3:07 PM (in response to magraomax)You know if it's working by checking the PP settings.
11. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
Jeff Bellune Mar 16, 2013 11:44 AM (in response to magraomax)Just delete the cuda_supported_cards.txt file and you'll be good to go.
Jeff
12. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
magraomax Mar 16, 2013 2:03 PM (in response to Jeff Bellune)Yes!!! realy now is working!!! thanks!!!!!!
13. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
Jeff Bellune Mar 16, 2013 2:05 PM (in response to magraomax)You're welcome.
Jeff
14. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
CouldntGuessAnotherName Sep 23, 2013 1:36 PM (in response to Jeff Bellune)Hello,
I have followed this thread and I amd still not able to change the default player, only the Adobe Player is shown. When I use GPUSniffer the GeForce GTX 760 card is detected. I added the card to the cuda_supported_cards.txt that didn't work. I renamed the cuda_supported_cards.txt file, that didn't solve the problem. When I start Premiere Pro (CS5) I can choose "Mercury Playback Engine GPU Acceleration from the Video Rendering and Playback Renderer drop down. The driver is version 327.23, there is no newer driver available.
Can any suggest why I cannot set the player to the video card?
TIA,
Lou
15. Re: GPUsniffer.exe will not accept my GeForce GTX 560 Ti using drivers newer than 296.10
JSS1138 Sep 23, 2013 4:47 PM (in response to CouldntGuessAnotherName)You're talking two different things here. The Player used has nothing to do with hardware acceleration. You can just leave it at Adobe Player.
