My page templates break any time I load a stylesheet. If I don't use a template or use one that doesn't have a stylesheet attached to it my products and catalog show up just fine. What's going on?
http://toffee01.businesscatalyst.com/order-test.html This one uses a template that loads a stylesheet and the bc content doesn't render.
http://toffee01.businesscatalyst.com/order2.html This one doesn't use a template and the content renders.
They're both rendering now.
Are you still having any issues?
Kind Regards,
Alex
Thanks for the response Alex,
Sadly, no they're not rendering for me. I can see everything except the BC-rendered content.
What are you trying to do there? Make eCommerce without using the eCommerce?
One page you linked does not exist.
http://toffee01.businesscatalyst.com/corporate.html Has no CSS added to it in the head at all
http://toffee01.businesscatalyst.com/onepoundbox.html This is not a BC product but static and it looks like you trying to do the shopping cart manually?
The BC guys will log in to your site and check it out but I see several things at a glance that likely to be wrong.
Hi Liam,
Thanks for your response. I want to use the built-in e-commerce capabilities of bc. The onepoundbox.html page is simply a placeholder to guide me when I apply styles to the bc layout for products.
When I try to use BC tags for the catalog or product {module_catalog,####} the dynamically-generated content doesn't seem to render if I have any stylesheet applied to the template.
If I remove the template, the content renders.
Here's the code in the editable region of my page:
<h1>Catalog Page</h1>
<p>{module_catalogue,192388}</p>
When I load the page: http://toffee01businesscatalyst.com/catalog.html
http://toffee01.businesscatalyst.com/catalog.html
the catalogue doesn't show up. I don't understand why.
UPDATE:
It seems to be working now. In the sketch.css file that was copied to my local machine by bc, there was a class named .clear. This class was collapsing the div and all the bc-rendered content was set to visiblility:hidden and width and height was zero. Not sure why the .clear class was being applied by bc, but I changed it to visible and set the width and height.
Does anybody know if there is a reason not to edit the skecth.css file used by bc to render e-commerce modules?
Thanks for everyone who helped. You helped steer me in the right direction.
