2 Replies Latest reply on Mar 5, 2013 11:45 PM by mizakr
    Terminate Workflow with Feedback
      hi guys,
      how can I show a message "Workflow could not be completed" when Workflow is Terminated?
      I try to create "Dynamic Participant Step" but not always the parameter will be correct --> then the workflow should be terminated and an author should get a feedback that something goes wrong..
      I try with "throw new WorkflowException(...);" but then the Workflow is terminated without any feedback that somethig goes wrong..
      I also try with "return null" - then the Author get a message ""Workflow could not be completed" but only if before this step is a participant step.
      When before is a Process Step, then the wrong step is repeated 4 times --> the workflow goes in STALE state and an author get any message...
        • 1. Re: Terminate Workflow with Feedback
          rush_pawan Level 4
          To cross check, when you throws an exception you dont throw exception based on raised exception like
          throw new WorkflowException(e);   // where e is an exception
          instead do
          String message = "Message you want to show";
          throw new WorkflowException(message);
          Also try to check your process step implementation for other issue, it seems that you are terminating your process step wrong, otherwise above will so the correct message.
          • 2. Re: Terminate Workflow with Feedback
            mizakr Level 1
            I terminate Workflow like this:
            if (...) {
                  return "some_group";
            } else {
                 throw new WorkflowException(new Message("Reason"));
            so it seems to be correct.. what you think?
