3 Replies Latest reply on Mar 7, 2013 9:07 AM by Sham HC
    Problem while creating new components
    anderson.nt Level 1
      I'm new to components. I'm trying to develop a custom component and my own components.
      For this I copied ‘text with image’ component  and I did some changes in dialog and jsp file and I renamed that component into ‘test’ component
      But this ‘test’ component  is not showing in General group in design mode. Also I searched in all the gropes that components is not there.  Do I need to register this test component in somewhere to display in design mode?
      And also I was thinking to do somechanges in pasys comp, So i copied parsys component from foundation path. I did not change anything on this. I just included that component in my jsp file like
      <cq:include path="test-out" resourceType="apps/Mywebsite/components/parsys" />
      But this component  is not coming in page. Do I need to register this parsys component in somewhere to display it in page?
      Please suggest some liks or answer.
        • 1. Re: Problem while creating new components
          HarishDv Level 1
          Hi anderson ,
          Firstly to show  your component in the design mode you have to add a property named "componentGroup" and the value of the group in which you need this component to be displayed.
          For displaying in general mode allowed parents property should be set to */parsys.
          Dont forget to change the jcr:title to "test".
          Secondly  for this <cq:include path="test-out" resourceType="apps/Mywebsite/components/parsys" />
          you can either use
          <cq:include path="test-out" resourceType="foundation/components/parsys" />
          or you can use the relative path , which might look something like
          <cq:include path="test-out" resourceType="components/parsys" />
          Harish
          • 2. Re: Problem while creating new components
            anderson.nt Level 1
            Hi Harish,
            All the property values are correct in my component as you said in your mail.
            Actually what I did is simple copy the existing Text & Image component and pasted in my application and I renamed Text & Image into ‘te’ and also I changed jcr:title value into ‘te’
            And componentGroup and allowedParents values are also correct. Please find the below my node properties values. I wonder why my “te” component is not coming in design model under General category when I edit my parsys component.
            • 3. Re: Problem while creating new components
              Sham HC Level 7
              Hi anderson,
                 Steps seems correct. Though looks strange. In the general mode select entire General Group category & then go to edit mode. See if your custom component is listed in sidekick.
              Sham
