I have a page that outputs a bunch of rows with form fields from a query. I am trying to bind a totals field to some simple math between a couple of the form fields and cannot get it working for some reason. What I am trying to do is:
bind = {((field1_#id# -field2_#id#) + #field3_#id#)}
What would be the best way to go about this?
function getResult(num1, num2, num3) {
//converts a blank, space, null, NaN, etc. to 0
var num1 = num1 || 0;
var num2 = num2 || 0;
var num3 = num3 || 0;
// For decimal numbers, use parseFloat instead
return parseInt(num1)-parseInt(num2)+parseInt(num3);
</script>
<!--- My example, just to simulate your context. --->
<cfset id="x">
<cfform number="mycfform">
First Number: <cfinput type="text" name="firstnumber_#id#" required="yes"><br>
Second Number: <cfinput type="text" name="secondnumber_#id#" required="yes"><br>
Third Number: <cfinput type="text" name="thirdnumber_#id#" required="yes"><br>
<!--- I have added the 'keyup' event to the last parameter to ensure the result appears immediately, on-key-up.--->
Calculation Result: <cfinput name="result" type="text" bind="javascript:getResult({firstnumber_#id#},{secondnumber_#id#},{thirdnumber_#id#@keyup})" bindonload="true">
</cfform>
