1. Re: Opening cell phone audio
SteveG(AudioMasters) Mar 5, 2013 9:47 AM (in response to ISCAW)1 person found this helpfulAs far as I can tell, these file types are merely containers, and if you change the extension on the file to either mp3 or wav, the appropriate Windows media converter will open it without you having to do anything else at all.
So before going any further, I suggest that you try changing .3ga to .wav or .mp3 and see what happens - this might be easier than you think!
2. Re: Opening cell phone audio
_durin_Mar 5, 2013 9:52 AM (in response to ISCAW)
The .3ga extension doesn't appear to be recognized by our importers, but you should be able to drag and drop these files, or set the Enable dropdown in the Open Files dialog to All Files to select and open these on OS X. Quicktime and the native OS X support will open them as .3g2 files, but the data appears to be fully imported and correct, at least in the test files I tried. I don't believe the same support exists on Windows.
edit: Steve G's comments may be accurate, depending on the specifics of the file. The compression method used may be compatible with other importers when forced through them. However, I believe that the 3GA format can also be DRM-locked, and therefore either encrypted or otherwise flagged in a manner which may or may not be covered under laws in your area.
3. Re: Opening cell phone audio
pedrogawdin Apr 16, 2014 8:50 PM (in response to ISCAW)1 person found this helpfulThe recommended solution to open cell phone audio like 3ga in Audition CS6 is convert 3ga to a more popular audio format like mp3 or wav and etc
I know a 3ga converter called iDealshare VideoGo which can convert 3GA to MP3, WAV, M4A, WMA, AC3, AAC, FLAC, OGG, AIFF, RA, AU, DTS, MP2, APE and etc.
I know a 3ga converter called iDealshare VideoGo which can convert 3GA to MP3, WAV, M4A, WMA, AC3, AAC, FLAC, OGG, AIFF, RA, AU, DTS, MP2, APE and etc. Step by step guide at http://www.idealshare.net/3ga-to-mp3-converter.html. -
4. Re: Opening cell phone audio
fadireslly Jul 15, 2014 3:08 AM (in response to ISCAW)1 person found this helpfulSome people suggest renaming the extension from .3ga to .mp3 or .3gp, and then you can play it on computer. That really works sometimes, but not always.
Why renaming works sometimes? Some players check file extension before check file content. These players recognize MP4/3GP format and AAC codec, but not .3ga extension. If you fool it to believe this is a supported file, MP3 or others, it continue to check the content of the file, and find it to be in 3GP format with AAC codec, then play it successfully.
Why renaming not always works? Changing file extension doesn't change file content and format, it is still a 3GP file. If your player doesn't support 3GP format and AAC codec, it cannot play your 3GA file whatever extension you change it to be.
To successfully play 3GA files on most popular players or devices, a recommended solution is convert 3GA files to MP3, WAV, M4A, FLAC, AC3 etc.
5. Re: Opening cell phone audio
flincherf May 11, 2015 8:49 PM (in response to ISCAW)1 person found this helpfulYou can rename the file extension to *mp3. And it will be compatible with your device SOMETIMES NOT ALWAYS. The best way is to convert it to a format which will be easily recognized by your CS6. I adopted the way in a post which introduced 3 ways to convert *3ga to *mp3.
6. Re: Opening cell phone audio
SteveG(AudioMasters) May 12, 2015 1:09 AM (in response to fadireslly)1 person found this helpfulfadireslly wrote:
It's a good question. I think that the answer to this is that it depends on how the file was built, and the header information contained within it. Just renaming the extension doesn't cut it - it's the metadata that gets looked at too. That's the problem with 'containers' - you can put whatever you like in there, and the only safe way to do it is to make sure that it only contains what it says. If there's conflicting metadata, then all bets are off.
At this point the only reliable (I think) way to deal with this, assuming that you know it's mp3 format data, is to open it as a .raw file and specify the appropriate decode information. This certainly used to work, but I haven't tried all the possible combinations to be sure that it's absolutely successful.
7. Re: Opening cell phone audio
Gloriaivy Jul 20, 2015 3:52 AM (in response to SteveG(AudioMasters))You should be able to drag and drop these .3ga files, or set the Enable dropdown in the Open Files dialog to All Files to select and open these on OS X. It is not suggested to change the file extension from .3ga to .mp3 or .3gp, since the renamed 3GA files can't be edited by any audio editor like Adobe Soundbooth, MP3 DirectCut, Audacity and Windows Live Movie Maker etc. There is no other way but to turn you 3ga files to Audition CS6 recognized formats. I have tried some video converters, but I found only Pavtube Video Converter Ultimate can perform well. This will really take a great convenience for you! You can have a try!
8. Re: Opening cell phone audio
bules58497394 Oct 25, 2016 10:31 PM (in response to ISCAW)If you want to play 3GA successfully every time and on every device the best solution is to convert 3GA to MP3, WAV, WMA, FLAC, AAC, AC3, M4A, etc,You may try use Avdshare Auido Converter.
9. Re: Opening cell phone audio
directioni47987592 Nov 22, 2016 6:43 PM (in response to bules58497394)Thank you for recommending, I just searched your mentioned software and also find its easy guide here 3GA Converter to MP3, WAV, WMA, FLAC, AAC, AC3, M4A – Avdshare
Just give it a try, and find it does works great.
