4 Replies Latest reply on Mar 5, 2013 11:33 AM by CEItim
    video replay button
    CEItim Level 1
      I've been following Schrene's example for implementing multiple videos and it works beautifully. This forum has been a tremendous resource, so thanks to all of you!
      I have a button that I've imported into Edge. I would like it to replay the currently playing video from the beginning on a button press. Does anyone know of any jQuery code that would replay a  video from the beginning?
      Thanks!
        • 1. Re: video replay button
          TimJaramillo Level 4
          Hi there,
          Not sure what your setup is, but the below code gets a video by div id, resets the video's currentTime to 0, and plays- effectively replaying the vid.
          var myVideo = document.getElementById("myVideoId");
          myVideo.currentTime = 0;
          myVideo.play();
          • 2. Re: video replay button
            CEItim Level 1
            Thanks, that works great for one video, but I'm trying to program a single button that can replay many different videos. All of my videos have a class of 'OSA', so I tried both this code:
            var myVideo = $(".OSA");
            myVideo.play();
            and this code, and neither work. Is there any way to do this?
            var myVideo = document.getElementsByClassName("OSA");
            myVideo.play();
            • 3. Re: video replay button
              Gotcha.
              Add a separate div id for each video. On click of your button that initializes the play state for each video, set a variable to store the "activeVideo" id. Then, use that "activeVideo" variable with the code I gave you.
              var myVideo = document.getElementById("activeVideo");
              myVideo.play();
              • 4. Re: video replay button
                CEItim Level 1
                Oh, ok, that's easy enough! Great!
